585,604 active members*
3,247 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > How important are fuses and where should I put them?
Results 1 to 7 of 7
    Jun 2017
    34
    I am building my contoll cabinet now and am thinking about fuses. Do I want them and where should I put them?
    I have an acorn board running 3 stepper online CL57Y drivers that supposedly draw 5 amps each.
    Jan 2005
    15362
    Re: How important are fuses and where should I put them?
    Quote Originally Posted by setlab View Post
    Unless they are light loads you want to use circuit breakers in your cabinet all main supplies Ac or Dc should have a Breaker or Fuse rated for load plus 150%
    Mactec54
    Dec 2003
    24220
    A big help is a copy of NFPA79 "Electrical Standards for Industrial Machinery"
    You can find a copy in PDF out there on the web, may be a little dated, but most still applies.
    Al.
    Albert E.
    Jun 2017
    34
    So say I have your standard mean well DC power supply, I would want a breaker or a fuse between its output and my drivers that can do 150% of the output?
    My driver power supply is a 48v 21a DC supply, is that considered bigger than a light load?
    I'll look around for the regulation book.
    Dec 2013
    5717
    Just to clarify, since your drives are rated at 5 amp input, you would want about a 7 amp slow-blow fuse between the power supply and each drive.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    24220
    Just as an aside, I much prefer linear power supplies due to their extra ruggedness.
    You do not need a regulated supply for steppers-servo's
    If, or when they fail, SMPS are much harder to fix.
    I would rather pay a little more, out of the gate for reliability.
    Just my 2c
    Al
    Albert E.
    Oct 2019
    Yes, you have to put the fuse in the circuit, Fuse should be fast blown before the acorn board supply.
    rest you can go with MCBs, But fuse is more responsive.
  1. X4 Fuses
    By dpaish in forum Syil Products
    Last Post: 12-28-2010, 03:57 AM
  2. where can i get these fuses
    By mycoolbeard in forum Uncategorised MetalWorking Machines
    Last Post: 07-17-2009, 10:16 AM
  3. Blowing fuses
    By kaderick in forum CNC Machine Related Electronics
    Last Post: 12-05-2006, 06:34 PM
  4. Blown Fuses
    By sommerjd in forum CNC Machine Related Electronics
    Last Post: 10-01-2006, 10:02 AM
  5. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
