600,772 active members*
2,765 visitors online*
Results 1 to 5 of 5
    Nov 2013
    16
    How Many PSU's?
    So first off, disregarding the PSU for the Stepper Motor drivers, this question is only related to the controller board i.e Controller Mk3/4.
    I have purchased two Mean Well RS 15 12 psu's, one to power the control board, the other to supply the output boards i.e 1 OptoCtrl (for E stop) , 2 OptoIso Boards ( one for tool height sensor, the other for limit switches) and an Output board 3/4 for the VFD inverter.
    So my question is: Is one PSU sufficient and reliably capable to supply these four boards? My main concern is the output board for the VFD which is also a 3 phase inverter.
    Cheers
    Dave
    Attachment 513384
    Jan 2019
    4
    Re: How Many PSU's?
    i run all the logic and peripheral side of my CNC off one PSU, inc coolant pumps etc. optoisolators etc draw very little current.
    the planet ccn board needs ~200mA according to spec sheets.
    with a 1.3A supply you should have a fair overhead for growth.
    Nov 2013
    16
    Re: How Many PSU's?
    Quote Originally Posted by fhyndoh View Post
    Thanks for your reply,
    I was advised that one PSU would be sufficient for three output boards, but my main concern was the supply to the VFD control board, and whether much like the main break out board needed its own PSU!
    Cheers
    Dave
    Jan 2019
    4
    Re: How Many PSU's?
    the VFD control board from planet CNC protects the control board from the high voltage AC and DC in the VFD, rather than generates the voltage itself. the VFD will usually eat wall AC and be very happy on that diet!
    M
    Nov 2013
    16
    Re: How Many PSU's?
    M
    :thumb:
  1. Replacing PSU with higher wattage PSU CO2 Laser
    By Dec0y in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2022, 07:58 AM
  2. CO2 PSU and TUBE ? Can I use a 40w PSU with a 50w tube ?
    By TrickyCNC in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 07-17-2014, 07:36 PM
  3. Questions about an old control/ its psu/ a new psu/ old servos
    By GM1G in forum CNC Machine Related Electronics
    Last Post: 05-26-2012, 08:56 PM
  4. PLC PSU
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 07-24-2011, 02:16 PM
  5. Please tell me if I´m totally off PSU
    By gotis in forum CNC Machine Related Electronics
    Last Post: 08-10-2006, 03:59 AM
