How to buy G10 FR4 G11 FR5 GPO3 G7 rigid laminate sheet?
If you want to buy G10 FR4 G11 FR5 GPO3 G7 rigid laminate sheet of ZTelec Group, you should choose a professional and reliable manufacturer. In this way, you can understand the performance of the products you need better and help the supplier to improve the performance of the laminate sheet you need. Then you can have a good command of the whole production and processing process of epoxy boards. What are good G10 FR4 G11 FR5 GPO3 G7 rigid laminate sheet manufacturer? You need to know from the following aspects.
1. Sample test
First of all, the G10 FR4 G11 FR5 GPO3 G7 rigid laminate sheet supplier certainly has the ability of testing sample. Because in the production of epoxy laminate sheet, different companies have different requirement. Most of the enterprises can provide G10 FR4 G11 FR5 GPO3 G7 rigid laminate sheet sample, the sample size is similar to A4 board. We can check the uniformity, texture, colour and lustre of laminate sheet, etc. through the samples.
2. Understand product performance
It is absolutely necessary to check whether the products are qualified or not. After getting the samples, we should also check the smoothness of the products and ask the manufacturer to provide the product parameters, reports and other product information. If the epoxy sheet supplier cannot provide specific product knowledge, it is not necessary to choose him.
3. Company strength
What are the previous partners of the G10 FR4 G11 FR5 GPO3 G7 rigid laminate sheet manufacturer? Where their products are used is also an important indicator for your consideration. That the product positioning of this manufacturer in its cooperative enterprise can also reflect his company strength. Because different cooperative enterprises have different quality control over the products, we can also get a good understanding of the company strength of this supplier through these comparisons.
4. Technology research and development
Afer all, G10 FR4 G11 FR5 GPO3 G7 rigid laminate sheet is a kind of production and processing. Because sometimes the customer is not professional, he needs to consult the epoxy sheet manufacturer to solve some problems. Whether this common technical ability is sufficient or not can be seen from the product solution ability of the manufacturer.
5. Reasonable prices
The price of G10 FR4 G11 FR5 GPO3 G7 rigid laminate sheet should be the concern of many people. When paying attention to the price, you should not just be attracted to it because of its low price. Because epoxy laminate sheet is made of glass fiber and epoxy resin by heating and pressuring, the cost of the product is obvious. If you simply just choose low price, I bet you your epoxy sheets must be substandard products.
