591,381 active members*
5,825 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How to disassemble Chinese BT30 Spindle
Results 1 to 5 of 5
    Apr 2021
    8
    Hello all, I need some help here.
    Just received my BT30 spindle from Aliexpress today and I have plans to change out the stock bearings with higer speed ones in few weeks time.
    The problem is I can't seem to unscrew the nut on the drawbar assembly using a wrench. Do I need a specialised tool for that nut?
    Attached is a pic of the mentioned nut in the yellow box.
    Thank you in advance for any help!
    Mar 2014
    1133
    Re: How to disassemble Chinese BT30 Spindle
    It is threaded I think. Does it not have flats to fit a wrench?
    Sent from my MI 5s Plus using Tapatalk
    Apr 2021
    8
    Quote Originally Posted by Azalin View Post
    I just figured it out. The collar below the nut needs to be removed first by loosening the grub screws on it's side.
    Next, loosen the 3 grub screws on the pulley to get it off the spindle shaft, and then I have access to the bolts on the cap below.
    I'll figure out the rest later today.
    Jul 2020
    Hope the thread is not too old ...
    I need some help and suggestions about taking out the drawbar from a similar bt30 chinese spindle ( see some pictures ).
    Cannot tell what exactly are those 3 grub screws ( 2 radial &very small, one larger on the axe) holding/presetting. Inside ( under the largest grub screw) there is a threaded bar.
    Reason to take it out is the holding force ( 250 lbs) measured with a clamprite gauge.
    Attached Thumbnails Attached Thumbnails 2024-08-23-20-48-13-053.jpg   2024-08-23-20-47-25-190.jpg   2024-08-23-20-46-10-460.jpg
    Jul 2020
    ok, it was simple ... unscrew the part at the end of the shaft ( third picture) from the drawbar inside ( the threaded bar I have mentioned before). the drawbar will go out through the taper side and the bellevilles will remain in the shaft.
    I have 90 springs, 23x12.4x1.4 (could be .3 ) donno what material is used. stack is 2 in parallel with 45 in series
    Most probably the drawbar was not properly pre-tensioned therefore giving only 250lbs.
  1. ATC Spindle Assembly using a Chinese BT30 Spindle Cartridge
    By yezard in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2020, 08:31 PM
  2. Chinese BT30 Spindle Upgrade
    By LBDesign in forum CNC "do-it-yourself"
    Last Post: 05-05-2020, 10:34 AM
  3. Chinese BT30 Spindle
    By NotASandwich in forum Vertical Mill, Lathe Project Log
    Last Post: 04-24-2019, 03:18 AM
  4. Replies: 3
    Last Post: 01-06-2018, 12:43 AM
  5. Chinese ATC Water Cooling Spindle with BT30 Tool Holder
    By Roctech-Cathy in forum Roctech CNC Routers
    Last Post: 01-17-2016, 01:05 PM
