547,427 active members*
1,746 visitors online*
Results 1 to 4 of 4
    Apr 2020
    16
    Post How-To: Feed Rate Calculation
    In general when it comes to building a tool path; you will need to determine the correct feed rate. Different materials have different surface speed ratings for any given type of cutter.
    As you can imagine the harder a material is, the slower we would set our speeds to. So, if we take the diameter of the cutter we would like to use and then also the surface speed of the material we would like to use, we can then calculate the correct RPM’s for our spindle.
    Next we need to know the tooth load and also the number of teeth for the cutter, now we can determine the correct feed rate.
    We can do this with the following calculations:
    Spindle Speed = 3.82 * Material Surface Speed / Cutter Diameter
    Feed Rate = Tooth Load * Number of Teeth * Spindle Speed
    So using the above we could take a 6mm Cutter, a Surface Speed of 280 and this would give us a Spindle Speed of 178.3rpm. Now we can take our Tooth Load, times it by the Number of Teeth our Cutter has, and then times that by our Spindle Speed. This gives us a feed rate of 0.7, all units being in English of course!
    Hope you found this useful...!
    Sep 2020
    Re: How-To: Feed Rate Calculation
    A parent's first task at the beach is to protect their child from sun exposure. There are two ways to do this. This is of course a high-quality cream and put on a panama hat on your child, you can find the best panama hat on https://top-mom.com/best-baby-sun-hat/.
    Sep 2020
    Nu-Way Bin Rentals specializes in customized 3 yard bin rental service. Whether you’re moving, cleaning out an office, on a production set, building a house, or need recycling at a professional event, our dumpster is versatile and handles all load types. We are the fastest, highest quality, most tailored bin rental service in the industry. Our bins are the cleanest you will ever see, every one is hand washed. We give lengthy rental times, and once you’re done we will come right out and remove your trash dumpster, or exchange it if you need it emptied. With one call or email, we will provide you with the most cost effective way for debris removal so you can focus on your project.
    Sep 2021
    Waste Removal USA offers roll-off dumpsters that make any residential & commercial renovation, cleaning, and demolition jobs easy. We make it fast and simple to book a roll-off dumpster for your home or business, and for any size project. Dumpsters can be delivered the same or next day if needed.
