591,380 active members*
6,966 visitors online*
Results 1 to 5 of 5
    May 2009
    1395
    How to find out if Spindle is Level to the Tabletop
    I know I can do this using a piece of paper under my endmill but to be accurate to the millimeter I wonder if there is a way to do this job using the DRO's.
    My tabletop cnc mill has a cutting area of 34"x46" and is all made with 3/8" aluminum plate/flatbar, 3 axis, 4 stepper motors, HY VFD and HY water cooled spindle. The tabletop is 5/8" MDF
    I have a home made touch probe and a simple script and when I use the Mach3 Auto tool Zero the endmill decent and when it touches the top of my 3/8" plate it goes up by 1" and the DRO reads 1". Now if I do the same in the opposite side of the table the results will be the same but it doesn't tell me if the tabletop at that point is perfectly level in relation to the first point.
    Any ideas how this can be done?
    Nicolas
    Dec 2008
    3156
    Re: How to find out if Spindle is Level to the Tabletop
    Your thread title is not what you are describing.
    It sounds as if you want a method to see if your spindle is trammed correctly .... that the spindle is perpendicular in both X and Y planes
    Done with an indicator held by a bar in a tool holder.
    Google "tramming a spindle".
    The larger swing around the spindle, the more accurate.
    Gauging tool lengths should be done in 1 place only, so your tools are relative to each other.
    May 2009
    1395
    Thanks for the help, I know about tramming and its not what I'm after.
    The cnc is brand new and haven't done any real cut yet. Since the tabletop is so large (34"x46") I was thinking how to verify if the depth of cut is equal at any place of the tabletop. I did a cut of a rectangle 1/8" deep and measuring the depth with a micrometer it shows 1/8" all along the groove. So its good.
    However I was thinking since I have a probe which establishes the 0" point of the surface before I start a cut if it was possible to use the probe. Perhaps with a script which registers the point at one end and then compares that value with a new value at another point of the table?
    Nicolas
    Dec 2008
    3156
    Quote Originally Posted by kolias View Post
    The method of tramming is to set spindle perpendicular to the table....after you check the gauging positions ARE at the same zero level. So you don't tramm your spindle to a slope.
    Another consequence from doing it, is to qualify the table surface is flat, that if you faced the table, it would be also be flat....
    May 2009
    1395
    I will give it a try, thanks
    Nicolas
  1. Round vs Square chinese spindle precision and noise level
    By Sam Banout in forum DIY CNC Router Table Machines
    Last Post: 10-15-2018, 05:26 PM
  2. Replies: 1
    Last Post: 02-29-2016, 01:26 AM
  3. Z Level Rough Vs Z Level Finish
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-19-2016, 03:37 AM
  4. HAAS VF0 1995 spindle oil level
    By turboboy in forum Haas Mills
    Last Post: 03-23-2007, 04:32 PM
  5. Where to find spindle adaptor ?
    By Roy Norris in forum Uncategorised MetalWorking Machines
    Last Post: 07-30-2005, 04:32 AM
