592,325 active members*
6,023 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How to fix Broken Chains
    May 2009
    1425
    The attached .dxf shows a piece I'm working on and have been able to cut all nicely except what I have marked as Area1,2,3. The reason is that the chains in each area are not connected (broken is some curves) and when I try to connect the 2 broken ends I get the message "these lines cant be connected.
    Is there any other command in McX5 which will allow me to fix these chains?
    Thank you
    Nicolas
    Dec 2008
    3169
    Re: How to fix Broken Chains
    Extend their lengths to overlap, and then trim back
    Problem with splines is they generate lots of point-to-point moves in the gcode file.
    There are ways to convert to arcs, if you wish. It is a bit of learning curve (excuse the pun)
    May 2009
    1425
    Never thought about extending the lines, will give it a try
    Nicolas
  1. I need cable chains.
    By KidKhaos in forum DIY CNC Router Table Machines
    Last Post: 12-18-2019, 01:18 PM
  2. cannot add more chains
    By greenene in forum Mastercam
    Last Post: 03-31-2013, 09:42 PM
  3. Cable Chains
    By Matt29c in forum Linear and Rotary Motion
    Last Post: 04-21-2008, 07:20 PM
  4. Help! Too many chains?
    By bcnc in forum Uncategorised CAM Discussion
    Last Post: 11-24-2007, 01:02 AM
