567,778 active members*
2,532 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > How to initial parameter error meldas 300 series
Results 1 to 16 of 16
    Aug 2007
    3
    Can anybody help me to find out how to inital parameter on meldas 300 series??
    because I have a problem with my machine and it need to initial first...
    my NC system 320 M
    this machine have NC alarm like:
    S02 INITIAL PARAM ERROR DIAGN 46
    Y03 AMP. UNEQUIPPED DIAGN UVW
    EMG EMERGENCY DIAGN SRV
    Z51 EE ROM ERROR
    pls anybody help me on this situation...
    Oct 2008
    you are have parameter of machine?
    Sep 2008
    138
    Hi
    Quote Originally Posted by gunawan_tehnik View Post
    my NC system 320 M
    Z51 EE ROM ERROR
    1) Save all of your machine data to disk.
    a) Tool data.
    b) Machine programs.
    c) Work offsets.
    d) Common variables.
    e) Parameters.
    2) Go back to “Machine parameters”
    3) Find “fix_P”
    4) Set it to a “1”
    5) Go to “Data I/O”
    6) Go to “Erase”
    7) In “Data( )” type “FORMAT”
    8) Go to “Input”
    9) In “#( )” type “4”
    10) Press <input> key.
    11) Power the NC off and then back on.
    12) Reload all of the saved data.
    Jan 2009
    I have an error also with a MELDAS 300 SERIES.
    Alarm Message 35 Cut off wire heat displace.
    I have no idea what this is trying to tell me.
    The Machine is a Mitsubishi M-V65B
    Any help would be greatly appreciated.
    Apr 2010
    MELDAS 300 SERIES PARAMETER
    my NC system 320 M
    Z51 EE ROM ERROR
    DO YOU HAVE PARAMETER LIST FOR MELDAS 300 SERIES ?
    Nov 2011
    please check the drive communication cable.
    note: the problem due to drive is not communicating with NC . may be one drive is not getting on. i think the error is not related with NC. this depends on drive malfunction or faulty please .
    CNC MANUALS
    Sep 2017
    3
    Re: How to initial parameter error meldas 300 series
    pls i have alarm "A103 thermokompensation
    Junior Member
    Apr 2018
    14
    Re: MELDAS 300 SERIES PARAMETER
    Quote Originally Posted by tonny2105 View Post
    anybody have copy of parameters for Traub Mx8F Meldas 300 series? serial and type in attached foto
    Oct 2017
    11
    Hi All
    I have TRAUB TND 200 with TX8F (Meldas Mitshubishi)
    I put all parameters directly from the Papers orginal together with the machine.
    Still fight with Parametres for SEVO I have two red errors
    S01 SERVO ALARM:PR 0027
    SY03 AMP. UNEQUIPPED S1
    And one yelow
    M02 NEED R.P. RTN 0004
    Any one have any information about how to set up the servo?
    I try to put some data according to some papers with servo together but nClick image for larger version.
    The problem which I find t was with Parameters 35 & 36 and also 57-64
    If any one have something from SERVICE manual with discription of parameters it will be helpfull.
    Oct 2020
    hey do you still need help. shoot me a text ill walk you through it i have all backups 8325633063
    Nov 2014
    3
    Quote Originally Posted by wesleyredondo View Post
    Hi, I have a Traub TND 300 with Meldas 300. The battery died and the machine lost parameters,I have some parameters saved on my computer. Can anyone help me how to insert them into the machine?
    Oct 2017
    11
    Hello Every One.
    Have You ever problems with diven tools motor ? I find in my TRAUB TND 200 AL 25 I suspect card on FR-SF-2-11K-T but need some kind of electronic to check all the Amplifeir FREQROL FR-SFJ.
    If some one need it parameters for TND 200 or TND 300. I have it
    Apr 2016
    5
    Hello!
    I have Traub TND200 who lost the parameters. Could you send them to t_nakov@yahoo.com
    Thank you very much in advance!
    Quote Originally Posted by MACS View Post
    Hello Every One.
    Nov 2012
    320
    Check your manuals.... The parameters are almost always part of the documentation set the machine integrator provides. Alternatively, the parameters are written into EEPROM (95% sure), so you rarely actually have to re-enter them. HOWEVER, the RAM will lose its memory if you lose power. You will need to reformat that, but this process won't change the parameters. You *will* lose any macros that are in memory, though. That can include tool change macros, if the machine builder used macros as a means of controlling tool change (sometimes they integrate with the PLC, and that is usually in EPROM).
    I would highly recommend that you SAVE your parameters, even if you think that they are lost, BEFORE you do anything else. You may very well realize that the data is still in the machine any that you lost it when you tried installing someone else's parameters. That would be highly unfortunate. There is zero downside to saving the parameters before you screw around with the machine. Just my 2 cents.
    Apr 2016
    5
    Yes, i have the parameters in my manual. The problem is that i don't have Parameter Nr.12 - select bits. There are the machine options in binary code. It is just empty space for this values in the parameter book. Without this i just can't become the ready on the machine.
    Mar 2023
    Turn off the power to the machine.
    Press and hold the "RESET" button and turn on the power to the machine.
    Keep holding the "RESET" button until the "INITIAL SETUP" screen appears.
    Use the arrow keys to select "INITIALIZE" and press "ENTER".
    Follow the prompts to initialize the machine.
    After completing the initialization process, you will need to set up the parameters for your machine. This can be done using the parameter list in the machine manual or by contacting the manufacturer for assistance.
    subway surfers
  1. Meldas 64 Lubrification parameter
    By paulosoares in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-21-2016, 09:16 AM
  2. Meldas L1 parameter changing
    By tomasz987 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-12-2016, 01:40 PM
  3. OKK MHA-400 MELDAS 83 LOSS PARAMETER
    By CNCTECHNOLOGY in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2012, 11:32 AM
  4. System Parameter Meldas 335
    By raetschakarle in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-04-2010, 11:15 AM
  5. Meldas 335M parameter!
    By Cole84 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-17-2008, 03:15 PM
