592,486 active members*
4,792 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How to Locate the Stock for Initial Cut
Results 1 to 5 of 5
    May 2009
    1425
    I have read some post on how to locate a stock for initial cnc cut but all are quite confusing for the basic knowledge I have. In the attached I picked a point in my CAM which can be anywhere but regardless where I pick how do I set my stock on the cnc table to align with the point I pick? The cnc is a home build machine about 3'x4' tabletop and I run Mach3.
    Nicolas
    Re: How to Locate the Stock for Initial Cut
    Quote Originally Posted by kolias View Post
    why are you picking up your Xo Y0 there ? pick it from the edge on the left or in the middle of the part would be the best
    May 2009
    1425
    Quote Originally Posted by MAZAKINTEGREX View Post
    I thought been close to origin it will be easier to move the stock (less distance to move) but I will give it a try, perhaps on the left.
    Thank for the help
    Nicolas
    May 2009
    1425
    This is how I did it. Moved the object to the lower left quadrant, the right object side touches the Y axis and the top object side touches the X axis. Now it should be easy to locate the object on the cnc tabletop. Will give it a try tomorrow
    Nicolas
    May 2009
    1425
    As per attached it worked very good
    Nicolas
  1. How do you cut your raw steel and aluminium stock?
    By men8ifr in forum MetalWork Discussion
    Last Post: 12-06-2018, 09:10 AM
  2. Replies: 1
    Last Post: 08-30-2015, 01:35 PM
  3. Pierce heights and initial cut heights needed
    By Beefy in forum Hypertherm Plasma
    Last Post: 12-07-2010, 01:25 PM
  4. what saw should i use to cut metal stock?
    By yang_cnc in forum Mini Lathe
    Last Post: 08-03-2009, 10:38 PM
  5. Need advise on band saw...or something to cut stock.
    By jinu117 in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2007, 02:01 PM
