600,838 active members*
3,353 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > how to manually open the automatic door
    Sep 2024
    3
    Exclamation how to manually open the automatic door
    Does anyone know how to manually open the automatic door on an Okuma U3000 or Okuma B750 when there's no electricity? I've been trying to figure out a safe and reliable way to do it but couldn't find clear guidance in the manuals.
    Any insights or tips would be greatly appreciated! ????
    Thanks in advance for your help!
    Feb 2007
    Re: how to manually open the automatic door
    You have to use the little red plastic key on the lock and unlock it. It can be done with a flathead screwdriver if the blade is the correct width.
    Sep 2024
    3
    thanks a lot
