591,385 active members*
5,381 visitors online*
IndustryArena Forum > CAM Software > CamWorks > How to output tool list
    Aug 2024
    4
    Hello,
    I configure the 3 axis postprocessor for myself.
    Can anybody knows if it's possible to output tool list at the begining of the NC file?
    Regards, Alex
    Aug 2024
    4
    Re: How to output tool list
    How to output tool list now is clear.
    Just need to output cutting time in nc header.
    Guys any hints...
    Quote Originally Posted by AlexNitti View Post
    Guys any hints...
    do you want the estimated time or the exact time?
    Aug 2024
    4
    estimated time
    Re: How to output tool list <-- change the title to "Machining time in header"
    Well there are 2 methods you can follow in your post. The "time estimate" I have attached can only be used if CAMWorks is adding custom properties to the SolidWorks file during posting. the 2nd method is more accurate and already built into every post but requires a replace section to be run after the "END OF TAPE" call.
    If you don't have the Custom Prop for Machine Time then for each operation you need to call "CALC_CW_ESTIMATED_MACHINE_TIME" and add a section "CALC_REPLACE_CODE" you need a place holder in your header ie "XX:XX:XX;" and then the section code as follows
    :SECTION=CALC_REPLACE_CODE
    :C: STRA={XX:XX:XX;}
    :C: STRB=TIME_HOURS
    :C: STRC={:XX:XX;}
    :C: STRCAT(STRB,STRC)
    :C: REPLACE(STRA,STRB)
    :C: STRA={XX:XX;}
    :C: STRB=TIME_MINUTES
    :C: STRC={:XX;}
    :C: STRA={XX;}
    :C: STRB=TIME_SECONDS
    you'll call this replace code in your ".LIB" file under "CALC_END_OF_TAPE" after "CALL(END_OF_TAPE)"
