591,534 active members*
5,409 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > How to pick a suitable mini CNC 5 axis milling machine
Results 1 to 6 of 6
    Mar 2016
    7
    I am looking for a mini CNC 5 axis metal milling machine, X/Y/Z ~ 300X400X200 about, and price about $5000.
    Adam
    Apr 2004
    5799
    Re: How to pick a suitable mini CNC 5 axis milling machine
    Just because you can put specifications and a price together doesn't mean you can actually find something with those specifications for that price.
    Andrew Werby
    Website
    Aug 2004
    782
    Cool !
    A HAAS UMC is about 140.000€, and just the same work envelople.
    As soon as You find something of similar for 5000€, please let us know.
    Nov 2013
    4827
    for that sort of money you are talking hobbyists level machines.
    What materials do you need to cut?
    Soft materials like wood and plastics can be cut with machines of modest rigidity. Soft metals like aluminum and brass require a much more rigid machine,
    and steel requires a machine of VASTLY increased rigidity. With every step up the rigidity ladder the price increases ten-fold.
    Craig
    Aug 2004
    782
    There is a mini jewellers 5-axis machine, something called about a "Mira".
    The old versions used precision planetary gearboxes, afaik, /h,
    and they are generally regarded as good to very good.
    Afaik.
    But used by the jewelry and watchmaking community, so MRR does not apply.
    The older machines used to cost about 20.000 $.
    Last time I looked there was no delivery and sales and prices were not displayed.
    Imo, ime.
    There is about 1% chance You can make a tiny serious 5-axis machine from scratch for 5000$.
    Unless You are used to making planetary gears, and know how to make them backlash-free.
    https://nscnc.com/about-us/
    Mar 2016
    7
    actually, I am looking for a CNC milling to do experiment instead of machining parts, as long as the slider be able to move, is OK.
  1. Replies: 2
    Last Post: 07-17-2020, 04:21 PM
  2. Mini CNC Milling Machine of 4-axis
    By Yornew in forum Tormach Personal CNC Mill
    Last Post: 04-05-2017, 10:27 AM
  3. Help choosing suitable milling machine
    By LikuiD in forum Uncategorised MetalWorking Machines
    Last Post: 09-16-2010, 09:37 PM
  4. Help to pick small (not mini) CNC Lathe
    By 5axis in forum Uncategorised MetalWorking Machines
    Last Post: 02-04-2004, 12:35 AM
