531,647 active members*
2,723 visitors online*
IndustryArena Forum > General Maintenance > Maintenance DIY Discussion > How to set contour overlap on Haas machine?
    Jul 2014
    199
    Machine is older, it is actually Mikron Haas VCE 500, but the control is very similar/equal to newer Haas mills.
    We have problem with this machine that it doesnt finish contour (toolpath) very precise, for example if you make a circle it will leave a small amount of material around start/end point of mill toolpath (circle).
    So we deal with this in CAM software, to extend this toolpath for example by 2mm... or make 2 circles instead of one.
    But this problem occurs only on this older Haas machine, we have 2 newer and they dont have this problem.
    Is there a parameter or setting on the machine which could overlap this contour for some amount so this problem wouldnt occur?
    Thanks in advance.
    Aug 2009
    760
    Re: How to set contour overlap on Haas machine?
    ..I see something about Setting 191 will affect tool path blending. Read more below
    https://www.haascnc.com/service/code...alue=G187.html
  1. How to set contour overlap on Haas machine?
    By allenp in forum Haas Mills
    Last Post: 11-15-2020, 08:13 AM
  2. HAAS Error 369 on Outside Contour
    By brcasey3 in forum G-Code Programing
    Last Post: 06-02-2017, 02:05 PM
  3. Overlap on my 1390 Omni laser machine
    By PCALLA in forum Omni CNC
    Last Post: 06-17-2016, 02:49 AM
  4. Treading overlap
    By Atilano in forum Community Club House
    Last Post: 01-17-2014, 03:39 PM
  5. Laserlabs Contour machine blues.
    By thebackshed in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 02-21-2008, 01:06 PM
