562,565 active members*
2,718 visitors online*
IndustryArena Forum > MetalWorking Machines > Drilling- and Milling Machines > How to set up air blast for dry milling on maching center?
    Junior Member
    Aug 2012
    257
    I am looking at milling 4140PH (Rc of 30) and from some reading the recommendation is to dry mill with air blast for chip removal as coolant will cause thermal shock to the carbide and early failure. Doing this in a maker space (not my machine) so limited on what I can set up or modify on the machine. I know it has coolant setup but not aware of any provision for air blast. How is this usually done other than just hand holding an air hose to keep the chips away from the cutter?
    Jan 2005
    14730
    Re: How to set up air blast for dry milling on maching center?
    Quote Originally Posted by Jim27 View Post
    There is always going to be someone that says no coolant is better in some cases it can be better, roughing 4140 is good to do without coolant, but finishing will give you better tool life and better finish with coolant, and this won't cause thermal shock when finishing, it has a lot to do with speeds / Feeds the Tool being used and the rigidity of the part and the machine plus spindle Hp correct chip load is important, and use max depth of cut
    Mactec54
  1. air blast
    By jarl85 in forum Cincinnati CNC
    Last Post: 07-15-2019, 07:19 PM
  2. PCB milling maching axis set up problems
    By Paul_radonc in forum PCB milling
    Last Post: 05-20-2015, 10:24 PM
  3. Air Blast
    By stevieboy in forum HURCO
    Last Post: 08-31-2011, 09:37 PM
  4. Air blast
    By MechanoMan in forum General MetalWork Discussion
    Last Post: 09-09-2009, 07:20 AM
  5. Air Blast
    By jybute in forum Haas Mills
    Last Post: 12-15-2007, 02:14 PM
