532,135 active members*
2,630 visitors online*
IndustryArena Forum > CAM Software > Mastercam > how to use the laptop mouse pad
    Nov 2020
    I am a MC newbie and just installed the demo. I opened a training file of a cube but I can't rotate it with the mouse pad. Do I need to get a separate wireless mouse? Do I need a special video card of some sort? When opening the app a pop-up appears stating: The minimum system requirement for OpenCL 1.2 with double precision has not been met.
    Flies Fast
    Dec 2008
    2803
    Re: how to use the laptop mouse pad
    A laptop mousepad does not have the scroll button needed for the zoom function... a separate mouse is required
    The boot warning is saying that your laptop is not meeting the ideal requirements ie CPU, graphics card etc
    If Mastercam fires up, it should work, but not at it's best
    ... note.... the demo version will not run forever, it is timed. So it will stop running... I think 1 year
    So practice, practice, practice
    Sep 2009
    75
    I would try a mouse button with a modifier key such as ctrl, shift or alt. It's a common function with numerous cad cam systems and the closer you emulate a desktop the happier you'll be. Can you find a cheap mouse? It doesn't care if it's wired or wireless.
    NX 10.0.3
  1. WIN 10 and BC 30 - Mouse Issue
    By Wolfman2332 in forum BobCad-Cam
    Last Post: 03-17-2018, 05:06 PM
  2. Replies: 0
    Last Post: 02-06-2017, 09:54 AM
  3. 3d mouse
    By tbaker2500 in forum SprutCAM
    Last Post: 03-10-2014, 04:59 AM
  4. Do you use more than KB/mouse for CAD?
    By loneengineer in forum Uncategorised CAD Discussion
    Last Post: 07-13-2012, 07:25 PM
  5. 3D Mouse
    By kendo in forum BobCad-Cam
    Last Post: 05-27-2008, 09:50 AM
