Hello all,
You have helped me immensely in the past and I am here again for help. My Original VDF died (my own fault for not having a brake resistor and stalling it out after 4 years of service) I have opted to replace with a Huanyang GT-7R5G-2 VFD. I attempted to buy a more reputable VFD (Hitachi or Delta) but was unable to find one what was rated for my spindle that didn't cost over $1500 so I will give this a try if I can just get the correct parameters to fire it up. It is currently wired just as my last one was prior to the stall. My specs are as follows
I have 220v wall power single phase on a 50 amp breaker
My spindle is a GDZ100-4.5 2400rpm 4.5Kw spindle (220v) That is a 400Hz frequency. it says rated 13A current.
Any help would be greatly appreciated and If it helps I can scan in the manual.
Thank you all!
Cheers
