562,489 active members*
3,727 visitors online*
IndustryArena Forum > WoodWorking > General WoodWorking > Huanyang vdf wired to C4N controller
    I’m a proud owner of the Cnc4newbie hsnc4848rp
    and I was needing some assistance, first off I’m almost done with my assembly and I am in the process of wiring. I have a huanyang VDF and spindle. I’ll suppy pictures. I was wondering how to wire the vfd to the controller. Also if you have any program info for the vfd that is compatible with uccnc.
    Jan 2005
    14727
    Re: Huanyang vdf wired to C4N controller
    Quote Originally Posted by joelbonato View Post
    It is quite straight forward you need a PWM to Analog 0-10v to control the spindle speed and a Relay to Turn it 0n /0ff, so check to see what you Hardware has
    The main Power wiring to the VFD Drive will connect to R / T Terminals Plus Ground/ Earth to the PE Terminal
    What are is the spindle motor specs???
    Mactec54
  1. Huanyang VDF E.o.L.A/E.o.L.d Error
    By 00chris in forum Spindles / VFD
    Last Post: 10-15-2022, 04:52 PM
  2. Copy Delta VDF settings? (VDF 022 EL 21 A)
    By stefancnc in forum Spindles / VFD
    Last Post: 03-10-2019, 01:54 AM
  3. Replies: 5
    Last Post: 02-02-2016, 03:01 PM
  4. Kelings Kl-vdf spindle controller
    By cairo2nz in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-29-2011, 09:43 PM
