585,991 active members*
5,740 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > HURCO Hawk 5M Control Pictures Needed
Results 1 to 19 of 19
    Nov 2017
    9
    Good Day,
    I recently purchased a HURCO Hawk 5M. It was running but the PO pulled 3 boards and had them repaired/cleanup. After getting them back, he had no time to re-install to run it. In comes me with the purchase. The PO is very reputable and I'm sure this will run. My issue is that I have no reference on which slot to insert the boards into and cables to hook them up inside the control box. Does anyone have a 5M that you could post pictures of the inside your control box for me so I can see where your boards are inserted?
    Thank you,
    JB
    May 2017
    58
    Boards from the main console? The computer box,or the drives in the cabinet? There are alot of boards.....
    Quote Originally Posted by dynajb View Post
    Good Day,
    Thank you,
    JB
    Nov 2017
    9
    Re: HURCO Hawk 5M Control Pictures Needed
    Good Point Sandvet03. I'm looking for pictures of the inside of the CPU (control board set). I'll take some of what mine currently looks like tonight to add to this post. Thank you, JB
    May 2017
    58
    I will take pictures of mine, might take me a day, just pinched my SI nerve so not mobile atm.
    Nov 2017
    9
    Sorry to hear that Sandvet03. Hopefully you can get some rest and feel better. I found some pics online but they are not very good quality and hard to zoom in on. Attached are pics of what's going on inside mine. When I turn it on, power comes on for about 5-10 seconds, everything lights up, and then it just turns off. Wasn't sure if maybe I hooked something up wrong. But, could very easily be something else...
    Thank you,
    JB
    Nov 2017
    9
    pic 2
    Nov 2017
    9
    pic 3 & 4
    May 2017
    58
    Are you running of a 3 phase line or a converter? Also when its starts the power up is it lighting the control console then rebooting? I would first reseat each conector. Then check your grounds. Sometimes temprature can make them finicky as well.
    pic 3 & 4
    Nov 2017
    9
    I am running a converter. When I turn it on, the control console does light up. But, only for about 3 seconds. Then it shuts off. I will double check all my connections, including the main power feeds. Very appreciative of all your help. JB
    Quote Originally Posted by Sandvet03 View Post
    May 2017
    58
    What size/type of converter? By shuts off, is it rebooting or compleate shut down and stays off?
    Nov 2017
    9
    I'm running a 5 hp rotary converter. It is a complete shut down. No rebooting.
    May 2017
    58
    You should have enough power to boot up then. When the boards were pulled he had them checked as well?
    Nov 2017
    9
    I'm pretty sure they did not have repairs made to them.
    Jun 2008
    1104
    pic 3 & 4
    Pic 4 has the I/O card (furthest away with the two grey plugs) in the wrong slot. Should be in the slot nearest you.
    May 2017
    58
    As usual Bloke is spot on. You can see the diffrence between your pic 4 and my pic.
    Quote Originally Posted by bloke View Post
    Nov 2017
    9
    Thank you. I resolved this issue, however, the same problem continues to exist. Does it appear that something is missing from the top right of the card in front of the CANBUS Controller? There are many pins sticking out, that I can't help but wonder if I missing something for those?
  17. #17
    Jun 2008
    1104
    Those pins are unused on the graphics card.
  18. #18
    May 2017
    58
    Maybe bloke can chime in on this, but there should be a test point for the voltages to the main board. Also when you power on can you feel the hard drive spin up? And is the cmos coin battery in place?
  19. #19
    May 2017
    58
    Idk if this will help you but here is some of the voltages and spots to check on the cabinet. Your incoming line voltage should b3 equal on all 3 legs at the first set of fuse blocks, the big grey ones prob 30 amp. Check for continuity on them whil powered off. Coming back down from the high voltage transformer, block 1,2,3 are 380 vac. The flip breaker next to them is 115 vac. #5 should be 115 vac this is your line voltagebto the dc distribution pcb. The case ground on the power supply runs to 15 and then to your main ground ensure this is tight and proper. Your console grounds run to 13, and 14. 14 case grounds your main transformer case. The only other thing I can see is hurco is expecting you to be sized for a 10kva load.
  1. Hurco Hawk 5M
    By Taz2012 in forum HURCO
    Last Post: 03-23-2017, 04:03 AM
  2. hurco hawk 5m
    By lopez473 in forum Spanish
    Last Post: 07-31-2014, 07:56 PM
  3. Hurco Hawk 40
    By JohnRF in forum HURCO
    Last Post: 10-31-2012, 05:15 AM
  4. Hurco Hawk 40
    By brucemazor in forum HURCO
    Last Post: 08-19-2011, 05:56 AM
  5. Hurco Hawk 30
    By jack_1960 in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2007, 01:27 PM
