532,030 active members*
3,659 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > HURCO VM10i with Winmax crazy lead outs problem (in compensation)
Results 1 to 8 of 8
    Jul 2014
    199
    Hello,
    we have this problem with this machine for long time now, I've tried getting help from official supplier multiple times, no luck, they just don't have expertise to understand what the problem with machine is and how to fix it.
    We also have HAAS and Fanuc machines here and we use same solidcam programs for all of them, but with different postprocessors of course, but the G-code looks similar or the same, but machine behaviour on Hurco is really different.
    I cant find in machine parameters or settings an option which would lead to solution to this.
    When the tool exits contour (with compensation active) it creates crazy move (arc move) returning to part and damaging it. So mill follows contour fine until lead out and decompensation point, then mill goes in arc move and returns to part damaging it, although there is lead out in solidcam to tangent line, no matter how long it is, it still won't follow it, it will crash into part. So I have to manually draw prolongation of that final contour line to lead mill well outside of milling contour so that final decompensation move wouldn't damage parts.
    In g-code there is nothing which would "tell" machine to create such a crazy move, but still it does that.
    Here is the example of what it should look like. The tool T2 is 12mm flat end mill (in solidcam I made it to be 12.2mm to add for offset compensation for operators if needed, so tool radius entered in tool table could be max 6.1mm).
    here is the example of this G code which makes same thing as all other programs do on this machine, returns to part in arc move after lead out (when it needs to decompensate):
    Code:
    N35 T2 M06
    N40 S1500 M3
    N45 G54
    N50 (F-KONTURA38)
    N55 M8
    N60 G0 X41.898 Y2.719
    N65 G43 H2 Z5.
    N70 G0 Z5.
    N75 G0 Z2.
    N80 G1 Z-2. F1000
    N85 G1 G41 D2 X36.614 Y-0.332 F300
    N90  X41. Y-7.929
    N95  Y-11.584
    N100 G3 X41. Y-38.416 I45. J-25.
    N105 G1 Y-42.236
    N110  X34.797 Y-48.439
    N115 G1 G40 D2 X39.111 Y-52.754
    N120 G0 Z5.
    N125 M9
    N130 M25
    N135 G53 Z0
    N140 G53 X300 Y400
    N145 M2
    E
    As you can see in my drawing (hopefully), those final two points for exiting the part contour and decompensation are shown on picture 1. Lead out in solidcam is tangent line, length 8mm (also shown on picture) and decompensation distance is 6.101mm (also shown on picture) so there is just enough distance so the machine would decompensate normally.
    Here below is shown what the mill path should look like and how it looks on every other machine except Hurco, where it looks like on second picture.
    Apr 2019
    54
    Re: HURCO VM10i with Winmax crazy lead outs problem (in compensation)
    Yes i figure out this but i use mastercam
    If t2 tool you must use t29-t30 is tool compensation
    tadasdan@gmail.com
    +37060022992
    Jul 2014
    199
    Quote Originally Posted by cnc-exit View Post
    tadasdan@gmail.com
    +37060022992
    No that is not correct for t2 is h2 and d2
    Apr 2019
    54
    Yes but hurco is difrent it has no h2 and d2 i use in from t29 to t30
    And if you dont do like that it make big circle, because use offset of tool lenght and it can be big diameter
    tadasdan@gmail.com
    +37060022992
    Apr 2019
    54
    D2=T29 - (witch has ofsrt volume example -0.02)
    tadasdan@gmail.com
    +37060022992
    Jul 2014
    199
    It can have and it does have h2 and d2. You just need to edit. I worked with that since beginning
    Aug 2009
    774
    ...I've seen this problem before. The easy fix was add a line/move or omit the G40 to any line after retracting Z above the Part.
    N115 G1 X39.111 Y-52.754
    N120 G0 Z5.
    N125 M9
    N126 G00G40Z0H0D0
    N130 M25
    N135 G53 Z0
    N140 G53 X300 Y400
    Jul 2014
    199
    Okay thanks, I will try it, but that is not the solution for a problem it is a patch.
    I would like to know and understand why machine does this, where in the control is logic for it, where in parameters are options to adjust it and modify such a behaviour.
  1. Hurco VM10i Post processor with rotary table
    By Radio01 in forum Postprocessor for CAM
    Last Post: 10-26-2019, 07:57 AM
  2. Replies: 1
    Last Post: 09-10-2019, 06:04 PM
  3. Hurco VM10i Adjust the clock on the control
    By porkchop831 in forum HURCO
    Last Post: 04-13-2017, 09:15 PM
  4. 4th axis on Hurco VM10i
    By johnhdsi in forum HURCO
    Last Post: 10-07-2014, 02:45 PM
  5. HURCO VM10i
    By 85burban in forum HURCO
    Last Post: 05-10-2014, 01:19 PM
