601,787 active members*
2,795 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > HY02D223B problem - set button not working ?
    Jul 2014
    Unhappy HY02D223B problem - set button not working ?
    Hi folks
    I'm having a hard time trying to configure my HY VFD.
    Everything seems normal (after starting the VFD, I can start the spindle, change its speed...)
    But when I want to program it : I press Program, I can change the number of the parameter, and when I click on "SET", nothing happen.
    I can't acces the value of any parameters.
    I've search this problem on the web, can't find any response.
    Is the unit locked ?
    Is there like a "hard" reset that I can do ?
    Do you think my unit may be defective ?
    Thank you !!
    Jul 2014
    Re: HY02D223B problem - set button not working ?
    I understand that if it was password protected, it would ask for a password..
    I've checked inside the control panel, the press button for SET works fine, and no components seem damaged (I've tested some diodes and resistors on the path of the button to the microcontroller)
    i'm stucked
  1. Replies: 7
    Last Post: 03-08-2022, 04:44 PM
  2. problem HY02D223B and mortor GDZ-80-2.2B 2.2khz 220volt
    By cap_pha in forum Spindles / VFD
    Last Post: 01-21-2017, 07:01 AM
  3. ESC Button not Working...
    By dneisler in forum Mach Software (ArtSoft software)
    Last Post: 03-24-2013, 02:09 AM
  4. Set jog to 10% with button/key
    By EL34 in forum Screen Layouts, Post Processors & Misc
    Last Post: 03-06-2012, 09:13 PM
