567,250 active members*
4,418 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > HY02D223B VFD - Simple Forward, Reverse, Stop. How do I do it?
    Mar 2023
    Hi All
    I thought this would be a simple 'Google' question, but I'm more confused than ever and can't find a result.
    I have a Router Table that I've hooked up with a HY02D223B VFD and Spindle. It works very well. But I'd rather have a Control box with large buttons that I can easily reach or bump a big red stop button with my knee so I don't need to fumble for the small stop control on the VFD.
    A simple 3 button control box is all I really need (Forward Run, Reverse Run, Stop) to replicate the buttons on the VFDs own control panel.
    Am I correct that all I need to do is buy the necessary 3 switch box and wire
    FOR - to output leg of Forward switch
    REV - to output leg of Reverse Switch
    RST - to output leg of Stop button switch
    DCM - to input leg of all 3 of the above.
    Is there any requirement for an earth wire in the above?
    Ensure Settings
    PD001 = 01 (External Source)
    PD044 = 02 (For Rotation)
    PD045 = 03 (Reverse Rotation)
    PD046 = 04 (STOP)
    Thank you for any input.
    Community Moderator
    Mar 2003
    35528
    Re: HY02D223B VFD - Simple Forward, Reverse, Stop. How do I do it?
    Yes, you are correct. No earth required, as it's just low voltage DC.
    However, you might want to locate the buttons so you can't accidentally hit reverse when it's running in forward.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2005
    15302
    Quote Originally Posted by aleron View Post
    Hi All
    Ensure Settings
    PD046 = 04 (STOP)
    If you have an 18000 RPM / 24,000 RPM spindle, then you would not be using a Reverse, this should be blocked, using Parameter PD023=0 Reverse Blocked most high-speed spindles like most Routers use do not allow the spindle to be reversed, most have an arrow laser etched on the Spindle for its rotation
    DCM is your circuit Ground / Common
    Mactec54
  1. Forward reverse step motor advice
    By Birdz in forum Stepper Motors / Drives
    Last Post: 03-19-2017, 02:53 PM
  2. Replies: 51
    Last Post: 05-15-2013, 10:23 AM
  3. Replies: 2
    Last Post: 02-21-2013, 07:58 PM
  4. Spindle Forward/Reverse = High/Low change
    By AdyAstley in forum Machines running Mach Software
    Last Post: 06-07-2007, 03:33 AM
  5. Can bad forward/reverse toggle cause motor not to spin?
    By ZipSnipe in forum General CNC Machine Related Electronics
    Last Post: 06-03-2006, 02:45 PM
