585,996 active members*
4,544 visitors online*
    Feb 2017
    hypertherm 45xp
    Hi guys I hope someone can shed some light on a problem I am having with my new Hypertherm Powermax 45xp. It doesn't matter if I am gouging or cutting, The arc just goes out mid way thru a run, its very intermittent. There is no water coming out of the nozzle just dry air. The ground is clean, the compressor is full. I have a moisture/water trap halfway down my airline to catch anything. The pressure at the moisture trap is good. The consumables are new. It is driving me up the wall ! I bought the machine because its a great piece of kit BUT until I get the wrinkle ironed out its a boat anchor.
    Can someone shed some light on what I am doing wrong please
    Regards Badger
    Jan 2008
    2247
    There are diagnostic codes on the display panel. You need to read the code immediately after it faults, then refer to the troubleshooting section in the operators manual. 99% of the time it will indicate an air pressure related issue. The pressure at your filter is different that the pressure at the inlet to the plasma....that is where you should read pressure and do so only when air is flowing at the torch. If your air hose is too long, too small of inside diameter, or filters are dropping too much pressure, that is my best guess with limited info. The diagnostics will give us better info.
    QUOTE=ssbadger;2006452]Hi guys I hope someone can shed some light on a problem I am having with my new Hypertherm Powermax 45xp. It doesn't matter if I am gouging or cutting, The arc just goes out mid way thru a run, its very intermittent. There is no water coming out of the nozzle just dry air. The ground is clean, the compressor is full. I have a moisture/water trap halfway down my airline to catch anything. The pressure at the moisture trap is good. The consumables are new. It is driving me up the wall ! I bought the machine because its a great piece of kit BUT until I get the wrinkle ironed out its a boat anchor.
    Regards Badger[/QUOTE]
    Feb 2017
    Re: hypertherm 45xp
    Thankyou Jim for the quick reply, I will see what shows up on the display the next time I use it
    Many thanks buddy
    Badger
  1. New DHC2, 45xp, have ohmic question
    By adown in forum PlasmaCam
    Last Post: 01-13-2017, 05:20 PM
  2. Hypertherm 65 or 85
    By Hellbent in forum Australia, New Zealand Club House
    Last Post: 07-17-2016, 10:59 PM
  3. hypertherm 600
    By Blowmeracing in forum Hypertherm Plasma
    Last Post: 03-06-2013, 02:08 AM
  4. Hypertherm MAX 70
    By blips in forum Hypertherm Plasma
    Last Post: 06-30-2012, 03:45 PM
  5. Hypertherm 900
    By matttargett4 in forum Waterjet General Topics
    Last Post: 11-24-2008, 01:47 PM
