585,931 active members*
5,759 visitors online*
    Apr 2013
    34
    I can not recover kflop.
    Hi Tom
    I tried to flash user memory, but the KMotion stopped responding. When I rebooted the computer and the Kflop, the Kflop did not boot. It flashes diodes several times and they go out.
    I already had this once, then recovery helped.
    But now during recovery, an "Communiocation error with KFlop" pops up after I apply power.
    It seems that the boot loader is damaged. How can I restore it?
    May 2006
    4045
    Re: I can not recover kflop.
    Hi mk00,
    Maybe you are performing the recovery steps incorrectly? Follow the procedure here.
    If still not recovering describe the steps you are doing and what happens.
    TK
    http://dynomotion.com
    Apr 2013
    34
    I tried a different version of the firmware file and it worked. May be my file is corrupted.
  1. need help recover tool changer.
    By 77volvo245 in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2012, 07:16 AM
  2. TOOL RECOVER PROBLEM
    By razzz in forum Haas Mills
    Last Post: 01-25-2012, 02:44 AM
  3. RECOVER PROGRAM
    By JERRYPEREZ in forum Haas Mills
    Last Post: 07-19-2010, 06:04 PM
