567,245 active members*
3,557 visitors online*
IndustryArena Forum > CNC Electronics > General CNC Machine Related Electronics > I have a huanyang hy02d211b VFD . 110 VAC water cooled spindle
Page 1 of 3 123
Results 1 to 20 of 41
    May 2016
    27
    It is rated for 24,000 rpm. I cannot achieve more 7,999 rpm any suggestions?
    Any Help is appreciated
    When running HZ registers 133.33 It is set to 400 hz 1.7 Amps
    Jan 2005
    15302
    Re: I have a huanyang hy02d211b VFD . 110 VAC water cooled spindle
    Quote Originally Posted by mpresti8 View Post
    1.7Ax3=5.1A at the spindle 8.8A at the supply.
    You did not say what spindle you have; it sounds like your Parameters are not set correctly.
    How many Amps is your AC supply??
    Mactec54
    May 2016
    27
    20 Amp circut
    This unit was running at Max revolution until this happened
    May 2016
    27
    I have the GDZ-80-1.5B 24000 rpm 1.5 KW 110V 400Hz 5ASpindle water cooled
    Jan 2005
    15302
    20 Amp circut
    Until what happened, did it overload or stall, is this being used from the KeyPad or by remote 0-10v??
    Mactec54
    May 2016
    27
    Run by the keypad on the front of the inverter no problems other than I wanted to slow it down because I believe it was running too fast for the surfacing blade i had on it. I was checking settings and the VI VR pin that you move the jumper on to change from the keypad operation to the Mach 3 software operation That is when i could not get it to work properly at this time it is shorted across the VR pins
    Company Representative
    Oct 2005
    896
    Did you check if this Parameter PD144: Max Motor RPM is set to 3000
    https://www.automationtechnologiesin...5-110vac-input
    May 2016
    27
    let me check that real fast
    PD144 = 3000
    May 2016
    27
    PD144 = 3000
    May 2016
    27
    Quote Originally Posted by automationtechinc View Post
    PD144 is set to 3000
    Jan 2005
    15302
    PD144 = 3000
    This Parameter PD144 is related to the Max RPM only.
    This is the Parameters you need for KeyPad / Pot use.
    Pot Control
    PD001=0
    PD002=1
    PD070=1
    JI Jumper 2-3=VI Position. You can try either position as some of these drives can be either for Pot use, these Parameters are important as well to make it run also for Pot control
    Mactec54
    May 2016
    27
    Pot Control
    PD001=0
    PD002=1
    PD070=1
    Those settings are correct still no luck
    Jan 2005
    15302
    Check the Jumper is not damaged.
    What are the Parameters you have set in the Drive
    Mactec54
    May 2016
    27
    Curent settings are as follows
    PD001=0
    PD002=0
    PD003=400
    PD005=400
    PD004=400
    PD007=.0.50
    PD009=15
    PD010=8
    PD011=133.33
    PD013=8 FACTORY RESET
    PD014=10
    PD015=10
    PD025=1
    PD027=0.80
    PD141=110
    PD142=5
    PD143=2
    PD144=3000
    Jumper is fine
    Jan 2005
    15302
    PD001=0
    PD002=0
    PD003=400
    PD005=400
    PD004=400
    PD007=.0.50
    PD009=15
    PD010=8
    PD011=133.33
    PD014=10
    PD015=10
    PD025=1
    PD027=0.80
    PD141=110
    PD142=5
    PD143=2
    PD144=3000
    Jumper is fine
    PD002=1 this needs to be 1 not 0
    PD070=1 also for the Pot to work
    PD007=20
    PD025=0 Default
    PD027=10 this is normally left at the default, if you want to use it than it should be set at the max of 10
    You also may need these 2 Parameters set also
    PD072=400
    PD073=133 Your Minimum Speed
    Mactec54
    May 2016
    27
    PD007=20
    PD025=0 Default
    PD072=400
    i made those inputs and still max rpm is7999 I think this thing is haunted
  17. #17
    Jan 2005
    15302
    There is another Parameter that is not set correct then, as that is sitting at your minimum speed setting, is there any others that you may have changed.
    Mactec54
  18. #18
    Jan 2005
    15302
    Are you trying to run from the KeyPad or from Mach3 if from Mach3 then you need a 0-10v Analog output from the Breakout Board, for this to work, if still only working from the KeyPad do the Arrow keys up /down change the speed.
    What Breakout Board are you using.
    Mactec54
  19. #19
    May 2016
    27
    I am running from the VFD not the computer or Mach 3
    Honestly this thing is driving me nuts.. One thing that I have seen on these YouTube videos is that when they change a value and press set the screen displays END mine does not display that
  20. #20
    Oct 2005
    896
    Give me a call, I will help you to check to find the problem
    The phone number is on our website:
    https://www.automationtechnologiesin...ucts-page/vfds
Page 1 of 3 123
