547,435 active members*
2,209 visitors online*
IndustryArena Forum > General Maintenance > SERVICE FOR CNC-MACHINES > I NEED HELP D: My Machine is not moving correctly.
    Exclamation I NEED HELP D: My Machine is not moving correctly.
    I have been having issues with the y-axis of my machine. When I move the machine along the y-axis the bearings seem to catch.
    I have searched through a number of forums and attempted several of the suggested fixes for this problem like loosening and tightening the set screws but I still can’t seem to get it to work properly.
    Thanks in advance!
    Lindsey
    Arrow Re: I NEED HELP D: My Machine is not moving correctly.
    1. machine manufacturer and type: Langmuir Systems CNC Plasma
    2. year of manufacture: 2019
    3. machine model: Crossfire
    4. control brand and model: Artsoft Mach3
    5. any machinery options/ accessories if they play into the issue: Everything on my machine are original factory parts
    Mechanical help.
    Apr 2004
    5406
    It's probably a mechanical ptoblem. Plasma cutting is a very messy process, and little bits of slag fly everywhere. With all the exposed screws and slides your pictures show, it's not surprising that some of them would lodge in inconvenient places and impede smooth motion. Try inspecting and cleaning all your bearings, slides, and screws, and the mating surfaces they're supposed to run on. If you get it back to running right, consider providing some bellows or other barrier systems to prevent this from happening again.
    Andrew Werby
    Website
  1. 440 not moving correctly after controller swap
    By cowanrg in forum Tormach Personal CNC Mill
    Last Post: 09-04-2016, 09:35 PM
  2. Machine won't zero return correctly
    By MachineKing in forum Bridgeport / Hardinge Mills
    Last Post: 04-07-2016, 03:11 PM
  3. Chinese Machine Not running Correctly
    By Eden_Stanger in forum Chinese Machines
    Last Post: 10-13-2013, 09:48 PM
  4. Probing does not work correctly when displaying machine co-ordinates
    By ex-egll in forum Mach Software (ArtSoft software)
    Last Post: 07-08-2013, 11:27 PM
  5. Machine not moving correctly
    By johntech in forum Machines running Mach Software
    Last Post: 02-10-2012, 03:44 AM
