556,800 active members*
2,376 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > I need to pick a 6040 router - could use some help.
    Aug 2005
    17
    I am looking to buy a 6040 router for under $2000, and I was looking at the FoxAlien and the various Chinese unbranded ones.
    I want to be able to sometimes cut aluminum even though I am getting it for wood, and I am under the impression that I want a ballscrew machine because belts don't like the forces. FoxAlien has a $2000 one, but it is a disposible brushed motor, so it would need at least another $300 put into it to make it decent.
    Genmistsu has their $999 machine, but it has regular threaded rod and is a 4040. It also has a cheap motor.
    Potential issues with the random Chinese machines are they may not work with Win64. They don't run GRBL, and I hear Mach3 control is less good? Not sure why or if that is true.
    I want extra Z height in case I want to sometimes use a vise or want to machine an electric guitar body. Once I limit myself to needing extra Z height, this is the one I keep coming back to. Can anyone tell me why this might be bad choice?
    I have decided on this one. Someone tell me why it is bad:
    https://www.ebay.com/itm/224328852649
    Nov 2020
    348
    Re: I need to pick a 6040 router - could use some help.
    for 2 grand I'd want a ballscrew, linear rails(not round ones) and maybe even closed loop steppers.
    Not interested in building it yourself? you can do something better with extrusions some 20-30mm aluminum plates and a few patient weeks of work. If you got lucky you could even snipe a small granite plate on ebay for cheap to mount everything on to.
    Aug 2005
    17
    Quote Originally Posted by ardenum View Post
    I am known to take on large projects but am overwhelmed redoing a large boiler replacement with new plumbing and wiring, solar, and minisplits.
    This unit does have 16mm ballscrews. The round shafts are 20mm on the Y axis, which seems pretty large. It’s 132lbs shipping weight.
  1. Anyone looking for a 6040 router to get started?
    By Rick_B in forum Australia, New Zealand Club House
    Last Post: 12-19-2018, 09:39 PM
  2. 6040 router
    By flewggle in forum Chinese Machines
    Last Post: 01-28-2017, 04:33 AM
  3. 4x4 cnc router build, nit pick my design!
    By jimmyjames1981 in forum DIY CNC Router Table Machines
    Last Post: 10-22-2012, 10:36 PM
  4. Router using old PCB pick & place machine
    By celephicus in forum Open Source CNC Machine Designs
    Last Post: 12-10-2010, 05:02 AM
  5. trying to pick a router
    By bandtank in forum DIY CNC Router Table Machines
    Last Post: 11-10-2010, 04:50 AM
