585,665 active members*
3,298 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > I really want to know how he's doing it !
Results 1 to 6 of 6
    Dec 2020
    In this video he managed to get this beautiful door ....I'm totaly new to this field
    can you guy show me what is he using ( the tools and the toolpath he's using) thanks
    https://m.youtube.com/watch?v=5Ua1_vdUnV0&t=286s
    Mar 2003
    35538
    Re: I really want to know how he's doing it !
    He's using a plunge roundover bit, making profile cuts ON the lines, followed by pocket toolpaths with a straight bit inside the lines he used for the profile cuts. Pretty basic stuff, once you have the drawing of the door.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2020
    Thanks a lot man! but I need more infos ...can you refer me to a source that can help me to understand how to do the same
    Feb 2007
    28
    Do you have a cnc machine? What software are you using?
    Jan 2005
    15362
    Quote Originally Posted by Blooper View Post
    First you have to have a CNC Router for the size of work you want to do that is a Chinese built CNC Router looks to be 8' x 4' then you need design software that you do your designs in from the design it goes into cam software there you convert the design into machine language call G-Code
    The cutters he is using in this video is a round-over Cutter or radius cutter similar to the snip there cutter would not of had the bearing , the cutouts where done with a straight cutter all of these cutters come in many different sizes and shapes to do what ever shape you want to cut
    Aspire software is good for this type of work, there are other software packages also https://www.vectric.com/products/aspire
    Attached Thumbnails Attached Thumbnails Roundover Cutter.PNG   Straight Cutter.PNG
    Mactec54
    Do you think straight cut 2 flute better than down cut spiral bit to do the pocketing in such door jobs? Should be ramp down cut for the straight bit? I didn't see any ramp moving by his videos (youtube suk tv channel)
    Sent from my SM-A507FN using Tapatalk
