527,854 active members*
2,217 visitors online*
Results 1 to 6 of 6
    Feb 2011
    24
    Ideas for a punch and die assembly
    Hi guys,
    I've been introduced with a new problem, and I want to ask If anyone had a similar one. I have to design a punch and die assembly for a sheet metal part that has some sort of foam fixated on it. Is that foam glued before the punch or is it put on by a separate tool/assembly. Also, what is the offset between the punch and the die in this situation. Do I go just by the thickness of the sheet metal, or the sheet metal with the foam, or something in between. I'll provide a picture of the part here.
    Thanks in advance Attachment 448642Click image for larger version.
Name:	WhatsApp Image 2020-09-13 at 10.35.22.jpg
ID:	448644Click image for larger version.
Name:	WhatsApp Image 2020-09-13 at 10.35.23.jpg
    Jun 2010
    4008
    Re: Ideas for a punch and die assembly
    Buy a stock punch press. Look up Roper-Whitney for examples.
    Put the metal part down against the metal die and bring the punch down to the part, and press.
    Cheers
    Roger
    Feb 2011
    24
    Hi RCaffin,
    To be honest, I don't think you understood quite well what my problem is.
    With all do respect.
    Jun 2010
    4008
    Well, I did have a problem understanding what was so difficult about punching a hole in some metal.
    Hum??
    Cheers
    Roger
    Feb 2011
    24
    Sorry, maybe I didn't put it correctly. I've worked with whole assemblies of making obliques like this from sheet metal. But I don't know does the foam go before or after making the oblique? And what should be the offset in between the male and female part of the oblique if it's done with the foam?
    Jun 2010
    4008
    I think we have a translation problem here. I do not understand what you mean. Sorry.
    Cheers
    Roger
  1. cnckad punch off the table euromac BX1000 top punch
    By renatomail in forum Post Processor Files
    Last Post: 10-19-2017, 11:55 AM
  2. punch tooling,cnc punch press tooling
    By sentool in forum News Announcements
    Last Post: 10-04-2011, 04:26 AM
  3. What punch oil?
    By maweme in forum MANUFACTURING PROCESSES
    Last Post: 11-18-2009, 11:03 AM
  4. Ballnut assembly ideas?
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 11-14-2007, 08:42 AM
