547,633 active members*
2,781 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > IGF for milling machine, OSP5000M-G. How to?
Results 1 to 7 of 7
    Mar 2007
    56
    Hi!
    I have a full set of diskettes with IGF software on them (with written serial numbers of my machine (OKUMA MC-4VA). So a question would be- how to install this IGF software, really want to take a look on this option. I haven't found any instructions in manuals about milling machine IGF, installing or use. There is additional PCBs with IGF marking installed on machine control panel, so everything should be there to use ir. Only - how? I would be very happy to hear from You.
    Guntis
    Mar 2009
    1663
    Re: IGF for milling machine, OSP5000M-G. How to?
    Find the tumbler marked "install". Maintenance menu pops up with OSP start.
    or
    Power up the MC with first floppy inserted.
    Mar 2007
    56
    Did that- no results.Changed floppy cable to IGF LOAD connector (there are two- one for system load, other for IGF load and file creating), LOAD tumbler switched to LOAD ON, on screen WAITING FOR FLOPPY, inserted floppy, pressed IGF LOAD button- nothing happens. Button is working- tested it with multimeter. Could it be some hidden parameter inside OSP5000M-G that allows IGF loading?
    Mar 2009
    1663
    call Dzintars. Looks like floppy is wrong.
    Mar 2007
    56
    Quote Originally Posted by Algirdas View Post
    Emm- who is Dzintars? About floppies- floppy drive is 100% working, IGF floppies there are two sets (new and old version)- I don't believe both sets are wrong or damaged, they were kept in good conditions. Something else is wrong there.
    Mar 2009
    1663
    wow :-) some Okuma owner in Latvia is asking who Dzintars is :-)
    Mar 2007
    56
    I know about that company, but Im not a factory, so never had real need of contacting them- believe it or not it is my hobby. I will try to contact owner directly, my good friend know him very well.
  1. trochoïdale milling on IGF?
    By duivenhok in forum Okuma
    Last Post: 03-17-2019, 08:56 PM
  2. IGF feed rate in milling
    By gunda in forum Okuma
    Last Post: 09-29-2014, 08:56 AM
  3. OSP5000M-G Backup
    By KHOATRANNGOC in forum Okuma
    Last Post: 09-19-2014, 02:39 AM
  4. OSP5000M-G - Machine / Work offsets
    By Dean0017 in forum Okuma
    Last Post: 12-30-2012, 08:26 AM
  5. osp5000m
    By stonehengemfg in forum Okuma
    Last Post: 06-12-2010, 03:39 PM
