548,315 active members*
2,286 visitors online*
Results 1 to 5 of 5
    Oct 2010
    62
    IJ mode in Mach 3
    I have had a problem posting from Solidcam to Mach 3. After searching online I have found that it is a common problem and that the IJ mode is set to absolute mode instead of incremental IJ mode.
    I have put G91.1 in the G code and it sorts out the problem. Apparently I can change the mode by going to General Config in Mach 3... however I cannot find a general config in Mach 3. There doesn't seem to be anything under the config menu that will do it.
    How do I do this in Mach 3 so that I don't have to edit the Gcode everytime?
    Mar 2003
    35475
    How old is your version of Mach3? In old (really old) versions, you can find what you're looking for in Config > State.
    However, adding G91.1 to your g-code is a much better choice than just changing it in Mach3. As the IJ mode is modal, if you load any g-code that has a G90.1, it'll reset the IJ mode to absolute.
    Having G91.1 in your g-code will insure that Mach3 runs the code correctly regardless of the state of the IJ mode when you load the g-code.
    What you should do is edit your post processor to have it automatically add the G91.1.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2007
    3745
    Gerry is right, but here is where I found it.
    On dropdown menu
    Config
    General Config
    Near center of page, Statup Modals
    IJ Mode, tick Inc.
    or in the initialization string add G91.1
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Re: IJ mode in Mach 3
    cannot find a general config in Mach 3 ... SAME PROBLEM
    Jun 2015
    3517
    hy, if you wish, i can create an app to handle automatically the IJs / kindly
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 11-13-2020, 04:35 PM
  2. mach 3 cv mode stalling
    By ihavenofish in forum Mach Software (ArtSoft software)
    Last Post: 01-20-2015, 03:36 AM
  3. Exact stop vs cv mode in Mach 3 from sheetcam
    By drieslaas in forum SheetCam
    Last Post: 06-30-2012, 09:37 AM
  4. Mach 3 Pausing after every arc and line while in CV mode?
    By gavztheouch in forum Mach Software (ArtSoft software)
    Last Post: 05-23-2012, 04:49 PM
  5. Mach 3 slow movement Jog, ok Auto Mode
    By cjchands in forum Machines running Mach Software
    Last Post: 12-20-2011, 02:04 PM
