545,577 active members*
7,152 visitors online*
IndustryArena Forum > CAM Software > Work-NC > Import cutter profile as dxf
    Apr 2021
    So I'm needing to import several cutter profiles as dxf files from NX. I have the cutter model, but don't know what I need to export/how to properly export from NX to make it able to be imported in WorkNC as a cutter profile to generate a tool. Help is appreciated!
    Moderator Dan B's Avatar
    Apr 2003
    1326
    Re: Import cutter profile as dxf
    If you want to use custom cutter profiles in WorkNC for anything other than 3-axis you will need to purchase the ATF module, or upgrade to WorkNC 2022. The ATF module allows for custom cutter profiles in any axis, which makes using circle segment cutters possible.
    At least that's how I understand it.
    Dan
  1. dxf import
    By Ronin26 in forum Mastercam
    Last Post: 11-09-2013, 11:37 PM
  2. DXF Import
    By Martin Long in forum Syil Products
    Last Post: 07-14-2008, 04:38 AM
  3. DXF Import on EZ-Plus
    By md63825 in forum Bridgeport / Hardinge Mills
    Last Post: 05-03-2007, 03:32 PM
  4. import DXF
    By qmas99 in forum FeatureCAM CAD/CAM
    Last Post: 07-19-2006, 01:08 PM
  5. DXF Import
    By Todd Price in forum Rhino 3D
    Last Post: 06-07-2004, 06:24 PM
