504,473 active members
3,116 visitors online
    Jan 2019
    3
    Inconel 600/625
    Hi, anyone with experience turning inco 600 and 625. I'm looking for some advice from proven methods , speeds, feeds, tooling for turning grooves in this horrible stuff. External tooling is 25mm shanks, grooves will be 26mm wide by 45mm deep or minus 90mm on diameter.
    Thanks.
    Aug 2015
    103
    Re: Inconel 600/625
    I have mostly done 718.
    My experience is the sfm has to be really low. like 50 - 150. Can't do huge depth of cuts. Inserts with a neutral rake will last longer preferable the harder grades.
    Apr 2013
    3
    Re: Inconel 600/625
    Hi I did cut this material on Mitsubishi CO2 laser that was easy like regular SS material only changed some setup on machine that's it.
  1. Inconel
    By bsharp in forum Machinist Hangout
    Last Post: 09-06-2015, 05:43 AM
  2. inconel 925
    By beau_cefus in forum Machinist Feedback
    Last Post: 08-22-2013, 02:33 PM
  3. Inconel 625
    By Jake E. in forum General Metalwork Discussion
    Last Post: 03-20-2013, 02:24 AM
  4. inconel 710
    By jaimeoro in forum Machinist Feedback
    Last Post: 03-24-2009, 07:25 AM
  5. inconel
    By positiverake1 in forum General Metalwork Discussion
    Last Post: 10-16-2007, 05:27 AM
