589,390 active members*
6,432 visitors online*
    Oct 2023
    Intermac Master 33 Axis Calibration
    I’ve got an Intermac 33 CNC where the a axis has travelled way past where it should, the fault codes on screen say that it has activated both the hardware up and down limits, which it hasn’t only one of the plungers on the limit switch is active, which is the front most one due to its position and the flags that activate the limit, and also “software end of range UP”. It is physically tilted pretty much 45 degrees anti clockwise from home. I need to know how to get it to drive back to being straight, which it won’t manually. And then how to calibrate the axis. Any help thank you
    Oct 2023
    The following fault codes appear on screen;
    AXS 629- Axis at the UP hardware limit switch. Axis A
    AXS 630 - Axis at the DOWN hardware limit switch. Axis A
    AXS 336 - Axis at software end of range UP. Axis A
    Mar 2010
    13
    Re: Intermac Master 33 Axis Calibration
    Dear NSSJRENG!
    How are you. I am nick. come from china. I am service engineer. befor work for intermac company. If you have any question about intermac master cnc and Genius CT . let me know . Maybe I can help you. my whatsapp ID +86 13585355877 my email adress : [email protected]. Hope a good info for you.
  1. machine intermac master 33
    By htm23 in forum CNC Machining Centers
    Last Post: 06-16-2024, 07:26 AM
  2. intermac master bevel
    By Giglesias in forum Glass, Plastic and Stone
    Last Post: 06-23-2013, 07:46 PM
  3. Intermac Master Bevel
    By Glass in forum Glass, Plastic and Stone
    Last Post: 07-13-2011, 06:42 PM
  4. INTERMAC MASTER MAXI
    By A Teixeira in forum Glass, Plastic and Stone
    Last Post: 01-28-2011, 06:38 PM
