547,519 active members*
2,142 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Intermittent motion control error messages
    Jun 2013
    3
    Hello,
    Wondering if anybody could shed some light on this fault
    1996 hurco hawk 5m ultimax 3 (dual monitor) Software v1.64.
    Machine had been sat, and had not been powered up for a couple of years.
    Everything starts up fine, all axes move / calibrate, etc.
    But I get Intermittent motion control error messages:
    (internal motion ctrl error on axis x,y,z, code = 2)
    or sometimes
    (motion ctrl queue brkpnt not detected on axis x,y,z.)
    This happens when I turn on the spindle , use the warm up function or run G code.
    The fault sometimes can happens within a couple of minutes of running, or machine can run fine for an hour or so before error message pop up and servos are shut down.
    Any input would be very much appreciated.
    Aug 2009
    1105
    Re: Intermittent motion control error messages
    ...possible Low input voltage or god forbid to High....check transformer taps Line to Line. If, you're trying to use a Rotary phase converter can cause problems too.
    Jun 2013
    3
    Quote Originally Posted by machinehop5 View Post
    Thanks for the response
    I just checked transformer no abnormal Readings.
    Also not using roarty phase converter.
  1. Replies: 0
    Last Post: 11-07-2018, 07:24 AM
  2. error messages
    By ANI-MAT in forum SIEMENS > Sinumerik 802D/840D/810D/828D
    Last Post: 04-06-2012, 11:10 AM
  3. Error messages
    By ErnieD in forum BobCad-Cam
    Last Post: 02-16-2012, 10:46 PM
  4. Motion control queue error?
    By mafitch7479 in forum HURCO
    Last Post: 12-23-2010, 04:51 PM
  5. error messages
    By sqatch in forum Dolphin CAD/CAM
    Last Post: 12-12-2007, 12:05 AM
