I have a mini mill (like a Precision Matthew’s) I have converted to cnc with ball screws and stepper motors.
When I run the x axis, there is an intermittent ‘thunk’ sound probably every 40mm or so. It sounds like it’s either at the end of the ball screw near the connector or even in the stepper motor itself. The x axis runs cleanly with no sound as it moves in x+ (to the right), but when I move it in x - (to the left) it gives a thunk sound every 30-40mm. I have adjusted the gibbs and loosened them tightened all the bolts. It only happens in one direction, which seems odd. It’s possible the stepper motor is not 100% in line with the ball screw and I will check this tonight. So I am trying to understand why the thunk sound only happens in 1 direction and what else to check. The parts are brand new and oiled.
