544,159 active members*
2,540 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Invert PWM on genuine Planet CNC MK3/3 Board
    Apr 2021
    Hello.
    I have a Planet CNC MK3/4 Controller board in combination with an JP-3163B Board.
    My Problem is, that I am getting 10V output at S0 (0RPM) Spindle speed and 0V output at S120000 (100%) Sindle Speed.
    I tried to check the box to invert output 2 (which is my PWM signal) but that makes no difference.
    Is there any way to work this in software or do I have to make a hardware fix?
    *I am using the old design Planet CNC Software.
    Moderator
    Mar 2017
    853
    Re: Invert PWM on genuine Planet CNC MK3/3 Board
    Why don't you use new software?
    Apr 2021
    Please excuse my late reply, my account had been blocked because I didn't want to enter my private phone number.
    I will try to give an sufficient detailed answer in this post since I will be able to read but may not be able to answer again.
    I am using the old software, because that is what was avaiable when I started using your products.
    The MK3/4 board is my second of your boards after my old one died.
    I did not try the new software because I was not able to find any information about a function for inverting here. Every pictures videos and documentary I found didn't show any additional options compared to the old version.
    If I switch to the new version, I will have to update the firmware on my board .. is it possible to reverse this update and later use the old software version again?
    Does the new version contain a function to invert the signal or was your post just an unrelated question?
  1. Replies: 5
    Last Post: 08-14-2019, 03:32 PM
  2. Experience with rotary tool changer on planet-cnc MK3
    By hoizlaender in forum PlanetCNC
    Last Post: 01-03-2019, 08:45 PM
  3. Planet CNC Mk3/4 Output count expansion
    By lh-cnc in forum PlanetCNC
    Last Post: 01-03-2019, 11:25 AM
  4. Fusion 360 to Planet-CNC MK3/4 controller POST PROCESSOR help
    By bstonterrier in forum Laser Control Software
    Last Post: 10-12-2018, 12:07 AM
  5. Replies: 2
    Last Post: 09-12-2017, 12:29 PM
