529,951 active members*
2,332 visitors online*
Results 1 to 5 of 5
    Jan 2014
    IPG Laser:System Error!
    I had a Chinese Fiber laser unit for 2 years
    Model: DTML-F(I)Pulsed Fiber Laser 5w-30w, IPG-YLP Control Card, EZCAD 2.5.3
    After initial power-up:
    I/o 4 input is on, light fires OK, but Marking is very Weak, I/o 4 input turns off.
    the second try to mark Ezcad displays "IPG Laser:System Error!"
    I believe either the software is not set up correctly, or the Laser Source is bad.
    please guide me what is the problem and how to fix it
    May 2019
    Re: IPG Laser:System Error!
    sorry to wake this thread up but did you figure out this issue i am having the same issue with my Raycus 30w laser
    May 2018
    27
    Turn on your laser source. I've had that error plenty of times and it's always when I forget to turn on the switch. If the switch is on then start checking to see if you have power to this source.
    I am also facing same issue in IPG Ylp 30w, I am also using same Ecad 2.14 software and same way there is one errors showing in machine “Fiber laser system error ” so if anyone have a Solutation then please let me help and tell me the reason and solution for the same
    Aug 2020
    20
    It seems to be the  Laser Marking Software error, the software installed is EZCAD , you can visit www.ezcad.net to contact the manufacturer.
  1. Replies: 0
    Last Post: 01-21-2016, 12:09 PM
  2. 904 system error on 6M
    By kstocklin in forum Fanuc
    Last Post: 01-31-2006, 01:57 AM
