585,715 active members*
3,856 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Is it better to have a z axis proximity switch vs an A axis on my slave motor? Mach3
    Question Is it better to have a z axis proximity switch vs an A axis on my slave motor? Mach3
    I am having problems with my z axis configuration and it is hitting the top of the unit. The configuration is messed up.
    As part of the solution I am thinking of robbing the pin for my a axis slaved motor to the y axis which already has a switch. Currently I have
    pin 10 to Emergency switch,
    pin 11 to Y axis,
    pin 12 to A axis which is slaved to X
    pin 13 to X axis
    pin 15 is to probe.
    On my parallel controller I am out of points now.
    Wouldn't it be better to have the Z limit for homing by moving it to pin used for A (Pin 12)?
    The Gantry seems to track fine and not even sure the Gantry uses the second limit to home with as a slave configuration.
    Jan 2018
    1516
    Re: Is it better to have a z axis proximity switch vs an A axis on my slave motor? M
    Quote Originally Posted by Davidtex0128 View Post
    pin 11 to Y axis,
    pin 13 to X axis
    pin 15 is to probe.
    Ideally. X should have both the switches wired in n eithher seriess for NC or paralell for NO going to 1 input leavinng an input left over for Z.
    Or better still you need a new controller with more inputs.
    I could run the A axis in series with the x if that is ok. I would think that would work so that if either hits the switch first then it trips all of the switches. I agree about getting a new card. I have 50 cutting boards to do and then I can do that. But for now that would give me a good z limit switch and allow me to fix my z limits and travel problems.
    Thanks,
  1. Mach3 ref all home with slave axis
    By HuguesP in forum Mach Software (ArtSoft software)
    Last Post: 12-01-2020, 08:25 PM
  2. Mach3 homing slave axis not squaring up
    By vdc-fx in forum Mach Software (ArtSoft software)
    Last Post: 10-13-2020, 10:51 PM
  3. Mach3 Slave Axis problem
    By Darian S in forum DIY CNC Router Table Machines
    Last Post: 07-31-2014, 04:06 PM
  4. G540 + Mach3 Slave Y & X axis
    By dglasco in forum Gecko Drives
    Last Post: 09-28-2013, 10:23 PM
  5. Replies: 8
    Last Post: 10-29-2009, 02:09 PM
