524,118 active members*
2,142 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Is it possible to adjust Fanuc Spindle motor acceleration/decelaration rate?
Results 1 to 6 of 6
    Jun 2020
    4
    Question Is it possible to adjust Fanuc Spindle motor acceleration/decelaration rate?
    We have an issue of spindle belt slipping on a Pinacho CNC Lathe ST310 with a rather large spindle (A2-11 nose, 16" hydraulic chuck and cylinder with 6" spindle bore). The spindle is driven via V-belts from a gearbox, which is driven by another belt set from Fanuc spindle motor. The slipping happens when the spindle start and stop (we it at around 500~700 RPM), slipping is on either the motor-gearbox belts or gearbox-spindle belt set. When we adjusted/tighten the belts, it get better only for a couple of weeks before it start slipping again. We also tried different brand of belts, but no luck.
    During the turning, it usually works just find. So I wonder if the acceleration and deceleration rate of the spindle when it start and stop rotating can be adjust? Would it help with the problem? Or should I not mess with it and look for other solutions?
    Thank you all in advance.
    Apr 2012
    37
    Re: Is it possible to adjust Fanuc Spindle motor acceleration/decelaration rate?
    nutnon,
    You didn't say control type/age so here are some parameters for more modern controls supporting Alpha servo system:
    4028 = acc/dec pattern
    4029 = current limit acc/dec
    4082 = acc/dec time
    Acc/dec pattern is found in the parameter manual for the control.
    The PMC program may have some timers expecting a speed arrival but you'll have to experiment.
    Jun 2020
    4
    Quote Originally Posted by freakycnc View Post
    nutnon,
    4082 = acc/dec time
    Thank you very much for your suggestion. I will look into the manual. By the way, the controller is Fanuc 0i-TF model.
    Jun 2020
    4
    After looking at the 0i-TF manual, I couldn't really find the same parameter. Are they not available in Fanuc 0i-TF controller?
    Apr 2011
    594
    They are available in the 0iF.
    The book says Parameters Nos. 4000 to 4799 are basically used with the serial spindle amplifier. For details of these parameters, refer to either of the following manuals and other related documents, depending on the spindle that is actually connected.
    • FANUC AC SPINDLE MOTOR ?i series Parameter Manual (B-65280EN)
    Jun 2020
    4
    Ok, got it. Seems like I will need to experiment parameter 4028, 4029, and 4030.
    Thank you for the help!
  1. Mitsubishi FR-SX-2-11K acceleration/deceleration rate
    By Elam Works in forum Spindles / VFD
    Last Post: 09-15-2014, 07:25 PM
  2. Acceleration Rate Mach3/others
    By metriccar in forum General CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-28-2013, 03:55 PM
  3. Moshidraw: adjust stepper acceleration??
    By Frogblender in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 07-03-2011, 02:52 PM
  4. X2 and G540 spindle acceleration rate.
    By TXFred in forum Benchtop Machines
    Last Post: 03-03-2011, 01:30 AM
  5. How to adjust spindle speed of a dc motor?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 01-25-2011, 07:44 AM
