587,006 active members*
2,894 visitors online*
Results 1 to 1 of 1
    Apr 2024
    4
    Is this machine rigid enough?
    Hey,
    I'm looking for my first lathe, and someone offered an Emco 120P in decent condition.
    Does anyone know if Emco 120P is able to turn 303 stainless steel, 20mm diameter? The speed of how fast it is able to turn 303ss it not a concern, since I will use it as prototyping.
    According to this link, it is about 330lb(150kg). Has 3.8/5.5hp main drive on the spindle with max speed 5000rpm, and max feed force in X/Z axis of 440lbs. Rapid traverse of 80IPM. Is it rigid enough to maintain rated tolerance, or will it vibrate too much?:
    https://bgp.nu/~tom/pub/EMCOTurn120P...nd%20Specs.pdf
    ?Does anyone know what grade of ballscrews these machines has?
    Best regards
    Cafke
    Attached Thumbnails Attached Thumbnails turn-120-cnc-p00508006_2.jpg   6883f6e02b5e6851bc6e32b1666c9c02bb389ff6.jpg
  1. Another machine rigid tapping (stepper machine)
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 02-12-2019, 05:53 PM
  2. 4k€ budget: rigid machine with ATC
    By bergstar in forum Want To Buy...Need help!
    Last Post: 07-18-2016, 02:31 PM
  3. Wich material use to get rigid machine?
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 04-06-2016, 09:26 PM
  4. CNC machine - small, rigid for steel?
    By craynerd in forum Uncategorised MetalWorking Machines
    Last Post: 02-04-2013, 07:03 PM
  5. Replies: 26
    Last Post: 09-04-2007, 08:20 PM
