586,024 active members*
4,172 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > is water cooled or air cooled?
Results 1 to 6 of 6
    Mar 2022
    5
    hey, I bought this spindle from a friend. i got hooked up with an inverter ,but I can't find a manual for it , I want to know how is cooled, can use someone's experience with spindles.
    It was on aBusellato CNC machine .
    Attached Thumbnails Attached Thumbnails IMG_0859.HEIC.jpg   IMG_0875.HEIC.jpg   IMG_0879.HEIC.jpg
    Jun 2005
    1730
    Re: is water cooled or air cooled?
    This type of spindle uses compress air for cooling. It takes a good sized compressor to get the volume of air required. You can see the air hose connections. Also ESS compressed air to change the tools
    Mar 2022
    5
    Quote Originally Posted by CNCMAN172 View Post
    it's weird that it uses compress air as cooling ,that means the air has to be discharged ,thus flowing out and losing compressor power just to cool it.
    Jun 2005
    1730
    Look for the spindle manual, the compressed air flows through air passages in spindle body and as air moves it cools the spindle. Many of these spindles also use ceramic bearings which handle higher rpm and run cool
    Mar 2022
    5
    I couldn't find it online
    Jan 2005
    15362
    Quote Originally Posted by Jee77 View Post
    It does not use compressed air for cooling, it is an air cooled spindle, which you can see by the fins on the motor housing, it may have a built in electric fan which would need to run to cool the spindle
    Your spindle has a tool changer so the fittings you see are all related to the tool changer and the air to keep chips out of the front of the spindle, so for the tool changer to work there will be some electrical sensors and air supply, this would be controlled with air solenoids, for changing the tools, don't ever activate the tool changer with the spindle running or it will be damaged
    Mactec54
  1. Replies: 8
    Last Post: 09-29-2021, 11:03 PM
  2. Spindle ER11 water cooled VS. ER16 air cooled
    By joaopcrodrigues in forum DIY CNC Router Table Machines
    Last Post: 11-06-2018, 05:47 PM
  3. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  4. Air Cooled vs Water Cooled Pros and Cons and Advice
    By Tundraman in forum Spindles / VFD
    Last Post: 06-20-2015, 08:41 PM
  5. Replies: 0
    Last Post: 04-27-2014, 03:49 AM
