600,839 active members*
2,938 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Issue with DNC on Fanuc Series 0-M System
    Mar 2025
    Post Issue with DNC on Fanuc Series 0-M System
    Previously, the DNC function could be used for online machining with a computer. However, the DNC has now stopped working for unknown reasons. The machine can still transfer programs for machining, but the CNC memory is too small to accommodate large programs. It is suspected that the DNC failure might be caused by incorrect machine parameter settings, as the communication cable is confirmed to be functional (since program transfers work). Requesting assistance to resolve this issue!
    Re: Issue with DNC on Fanuc Series 0-M System
    Quote Originally Posted by GJMPro View Post
    You can check if the baud rates are matching or not between cnc and pc?
    Parameters 5001 and 5110–5112 (Baud Rate, Stop Bits, Parity)
    Dec 2009
    1024
    Quote Originally Posted by cncmakers001 View Post
    Do you even read that his system is 0-M?
    Do you really understand that parameters you said are not for this controller?
    People these days are not paying attention at all on what people are writing
  1. Replies: 7
    Last Post: 10-13-2024, 05:07 PM
  2. Replies: 1
    Last Post: 05-08-2023, 09:36 AM
  3. Fanuc Ot DNC issue
    By BrendanF in forum Fanuc
    Last Post: 07-19-2009, 06:57 AM
  4. DNC communication (Fanuc 0 Series)
    By PinMan in forum Fanuc
    Last Post: 09-02-2008, 01:13 PM
  5. Fanuc Series O-M DNC question
    By Blu91Z28 in forum Fanuc
    Last Post: 06-30-2006, 05:45 PM
