541,080 active members*
3,015 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > issue with stepper motor using A4988,CNC sheild and grbl library
Results 1 to 6 of 6
    The stepper motor oscillates around the starting point and arround the stopping point when using the grbl library as you can see in this short clip
    https://www.youtube.com/watch?v=JrjhW3ktgqU
    If I do not use the liberary, the stepper motor behaves well.
    Any help will be appreciated.
    Philip
    Mar 2015
    300
    Re: issue with stepper motor using A4988,CNC sheild and grbl library
    Reduce the acceleration and let us know if it helped
    the motor is running perfect now
    many thanks
    the accelaration setting was
    $120 = 10.000 (x accel, mm/sec^2)
    I took it up to
    >>> $120=200
    It is working fine now
    As I have no clue what I am doing as this is my first chance to play with the cnc sheild, I realy appreciate any input.
    Many thanks hfjbuis
    Mar 2015
    300
    Great to hear it is working.
    Enjoy learning to use steppers.
    Huub
    I could have stopped the reporting here, but I did not feel comfortable in case someone reading I might confuse him.
    I find several issues
    while it is true that pumping the acceleration up has helped(I guess overcoming the rotor inertia) the root cause of my issue was that one of the motor wires was bad quality and break. It was tricky because visual inspection shows ok.
    Due to running the motor single phase, there was hesitation in the take-off and landing of the motor. The higher accelaration helped overcome this hesitation. But the root cause was a lose wire,
    So now I brought the accelaration down to 50 and corrected the lose wire and things are more than perfect.
    The reason I found the lose wire because the motor take off in a different direction every time I give a command to rotate possitive Y.
    I searched the net and found quite few people have this issue and where able to nail it down to lose wire.
    conclusion : if the motor decides to rotate in a different direction while given the same command (Say +y ) first suspicions should go to single phase operation due to lose wire or failed motor or something of that sort.
    Thanks hfjbuis for taking the time to post in my thread.
    Mar 2015
    300
    Thanks for reporting the actual cause. Now we both have learned something new
    Huub
  1. GRBL: EN pin on the Pololu A4988 driver board is staying high.
    By crchisholm in forum Uncategorised CAM Discussion
    Last Post: 02-24-2018, 01:55 AM
  2. Replies: 1
    Last Post: 03-20-2017, 05:47 PM
  3. Replies: 3
    Last Post: 06-03-2016, 02:48 PM
  4. A4988 and this Japanese Stepper Motor strong enough?
    By Topicawox in forum General CNC Machine Related Electronics
    Last Post: 05-24-2013, 12:44 AM
