My mill uses a RPi4 with the latest 64-bit release of PlanetCNC. For initial setup I have been using a LCD display connected to the HDMI port on the RPi but am planning on using a tablet to interface with the mill eventually. The RPi is set up to connect to a wireless router in my shop (currently not connected to my main router or the internet). The tablet connects to the router and uses a VNC app (AVNC) to connect to the RPi. I currently can control the RPi with either a wireless keyboard/mouse combo which is connected via USB dongle to the RPi or via the tablet using touch screen.
This seems to work reasonably well with a couple exceptions I just noticed.
1) When I am using the tablet to control TNG if I attempt to use the jog control touching and holding the direction triggers the same as a quick click of the mouse. As a result, the spindle shifts a very short distance. It is much further than the step but does not function like I would have expected. It is possible this is how the VNC is set up so this may not be something that TNG can do anything about.
2) When using the mouse and the HDMI screen to jog the spindle, all works as expected. Holding the mouse button on the jog button moves the spindle quickly and stops as soon as I release the button. If no monitor is connected and I am using the tablet only for display and use the mouse to jog the spindle, pressing the jog button moves the spindle but rather erratically. Quickly pressing and releasing the jog will either do nothing or it will move approximately 1". It is not predictable which, but it is impossible to do anything other than slightly more than a step and around 1". It is impossible to move to a desired location without under/overshooting the mark. Also, since I don't have limit switches on my machine this leads to the possibility of a crash or requires me to use a smaller usable area.
I can provide any logs that might help explain the behavior. I didn't see a location of such a log in the profile directory but will look again when I get a chance. If a video would help I can do that too.
EDIT: I am also open to using a handwheel but since this is my first CNC mill I wanted to get a little time under my belt prior to making another big purchase. In either case, I want to make sure the mill works as intended prior to adding more components to it.
