525,382 active members*
2,662 visitors online*
Thread: Jogging XYZ
    Jul 2020
    14
    Jogging XYZ
    Hi all.
    Just bought a CNCEST 3040 milling machine, downloaded mach3 demo and tried to jog the XYZ but the machine isn’t moving although the coordinates are moving on the DRO, can someone please tell me if I’m missing something. I’ve set the ports and pins, motor tuning as shown on YouTube video.
    Nov 2007
    270
    Re: Jogging XYZ
    Make sure you have the right settings in the ports and pins tab , check the pc in device manager to see what port address your printer port is most common is 378 but it may be something else like e000 or d800 . After finding the correct port address put that in the 1 port . Are you using a laptop ? If so a laptop will only work with a motion controller ie. Smooth stepper
  1. Replies: 2
    Last Post: 06-05-2020, 09:47 AM
  2. No jogging
    By Jigantor in forum General Off Topic Discussions
    Last Post: 06-14-2016, 09:44 PM
  3. Jogging control
    By beermkr in forum LinuxCNC (formerly EMC2)
    Last Post: 01-31-2011, 03:43 AM
  4. jogging
    By mr.merlin in forum TurboCNC
    Last Post: 08-01-2007, 01:48 AM
  5. jogging
    By nebyeh in forum DIY CNC Router Table Machines
    Last Post: 12-20-2006, 01:27 AM
