548,478 active members*
2,481 visitors online*
Results 1 to 8 of 8
    JPG / MeshCAM
    So new I have nothing but questions however knowledge is starting to create questions of substance ..sort of ...
    My hobby is building wood grips for old west Six-Guns for competition shooters
    Arthritis is ravaging my hands so I am searching out CNC router to do grunt work of reducing a .500"X4.5"X3" block of wood to a nearly finished 1/2 of a pair of grips ..from there do final fit/finish
    I see MeshCAM can work with JPG ..is that the same as JPEG as in a digitized picture ..or is JPG a format that CAD programs issue ???
    Can MeshCAM do anything with a JPEG photo?? ...PLEASE say yes!!!!!!!!!!!!!!!
    Bear
    Apr 2004
    5419
    Re: JPG / MeshCAM
    I believe it can generate a heightfield mesh from a JPG; that's where it analyzes a grayscale image, placing points on a vertical scale that (usually) sends dark pixels low and light ones high. Then it constructs a mesh that connects the dots and a program that will carve the mesh. This would typically be used to create low-relief decorative effects on the surface of a form, rather than the form itself. So if you wanted, say, rattlesnake scales on your grips instead of the normal checkering, it could do that, using a high-def photo of the snakeskin. But you wouldn't use it to construct the grips themselves; you'd use CAD software for that.
    Andrew Werby
    Website
    Re: JPG / MeshCAM
    Quote Originally Posted by awerby View Post
    Thanks awerby
    As I say I'm really new ..so I am far behind the curve of knowledge ..not even knowing which machine (small for sure) I will settle on ..but the education to this point is saying spindle not router ..full screw on XYZ ..with a lot more questions ..like start lesser machine wise to learn then step up ..so CAD program may or may not be tied to the first machine ..just thinking as a newbie that the more factory support with my limited knowledge that the CAD tied to the machine of choice might ease the start up process ..though I don't see the CAD stuff particularly tied to any one certain CAD but more in which/what type file the CAD can issue ..then that gets the question of which CAD and it's capability I actually need... 2D, 2.5D or 3D as at this point I am not sure where each of these levels stop or start with in building a wood grip with curves,straights, angles a variable thickness
    Bear
    Mar 2003
    35476
    Re: JPG / MeshCAM
    Yes, but jpg (or other images) won't really do what you want.
    You really want to create 3D CAD models of your grips. With a good model, the machine will do 99% of the work for you.
    If this is a hobby, download Fusion 360, and sign up for a free hobby license.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Re: JPG / MeshCAM
    Thanks awerby
    Bear
    Re: JPG / MeshCAM
    Thanks ger21
    It is hobby but I do sell some also.. so I'll not sail under a false flag ..so that begs the question of a free or low cost 3D CAD ..even the "start-up" is $500 per year ..I cannot afford that
    Bear
    Apr 2004
    5419
    Re: JPG / MeshCAM
    To make normal pistol grips with curved surfaces, you'd need a 3D program. 2D would just get you a cutout of the shape, and 2,5D would give you the cutout with "stairsteps" on the surface.
    If you're looking for a simple but powerful 3D CAD program, take a look at MOI (Moment of Inspiration). Written by the original author of Rhino, it's like a stripped-down version at a much lower price ($265 if you get it from us) and you don't have to pay it every year...
    Andrew Werby
    Website
    Feb 2011
    270
    Re: JPG / MeshCAM
    I realize that this post is a couple of years old, however, I worked extensively with MeshCAM Art to create the Rattler in these photos. I also worked with Corel DRAW to create the artwork used. I like CorelDraw, because of it's many import/export options to convert files from (for example *.JPG format to *.PNG format, etc.) And since it is a vector-based drawing program, it allows for many CAD options as well as bitmap creation/editing. Since MeshCAM Art works with up to 32 colors, it can be very confusing, to set up the color pallettes used in CD (Corel DRAW). The basic thing to remember, is the MCA (MeshCAM Art) likes colors to be in the RGB format. Generally, setting things up in CD to use "Web Page Compatible Colors" (RGB) will do the trick. I speak in past tense, because my workshop burned to the ground, and I lost every thing I owned in 2019. I have since rebuilt the shop, and am in the process of replacing tools. (And getting back into CNC). Before the fire, I used MCA to create many thousands of carvings in Oak (recycled tractor-trailer flooring). Hope that this info helps someone. Have a Blessed Day!
    -Mike
  1. new to cnc, need help with meshcam
    By lostit in forum GRZ Software- MeshCAM
    Last Post: 08-27-2018, 03:56 PM
  2. Beneficial To Upgrade to MeshCAM 6 (and/or MeshCAM 7)?
    By SeeAnnSee in forum GRZ Software- MeshCAM
    Last Post: 06-26-2018, 12:15 AM
  3. Meshcam ????
    By wmpinion in forum Uncategorised CAM Discussion
    Last Post: 08-21-2013, 02:13 AM
  4. Meshcam
    By speedtwin69 in forum GRZ Software- MeshCAM
    Last Post: 03-24-2013, 05:41 AM
  5. New To MeshCAM
    By cartman635 in forum GRZ Software- MeshCAM
    Last Post: 07-10-2012, 05:33 PM
