540,540 active members*
5,137 visitors online*
    Oct 2008
    21
    Jumpy feed in all axis during G1, smooth feed during jog
    Hi all. My first post in this section of the forum, long time forum user/lurker. I have a little enco 9x20 lathe that I converted to cnc, running on a 5 axis breakout and mach3. I had this project in storage for a while and just got determined to complete it. I've got the spindle lined out, my pendant repaired and working great, and now my feed is giving me headaches. I can feed smoothly in job, but when I G1, I get short bursts of movement. If I'm turning square stuff, the dimensions come out, but this won't do for any radii or angles. No good for threads either. Seems to me that it must be a setting since the jog works smoothly. Any advice?
    Oct 2008
    21
    Re: Jumpy feed in all axis during G1, smooth feed during jog
    It was due to an older version of Mach3 on that computer. I remembered I had been running it off of another PC and viola, no more issue.
  1. custom tapping cycle to feed in/feed out at different feed
    By PRINT_FX in forum Parametric Programing
    Last Post: 03-22-2019, 08:01 PM
  2. cutter leaving feed lines at high feed rates-walter prototyp end mill
    By shimmwagen in forum DNC Problems and Solutions
    Last Post: 02-07-2014, 11:44 PM
  3. Replies: 0
    Last Post: 01-23-2014, 08:54 PM
  4. Replies: 11
    Last Post: 10-13-2007, 07:03 AM
  5. Smooth Jogging, Jumpy During G-Code
    By cresusillo in forum Machines running Mach Software
    Last Post: 06-18-2007, 04:54 PM
