545,780 active members*
2,293 visitors online*
Results 1 to 20 of 20
    Jul 2018
    47
    KFLOP Stepper Motor Encoder Set up
    Hi Tom
    After getting my Kstep/Kflop working fine a few months ago with external jog buttons and being away with work for 3 months in the US . I have decided to get the Kanalog connected after a few hiccups with which bits the step/dir controls are through JP5/JP26 connectors it is all working now as it was before adding the Kanalog
    i have now added a 200 PPR optical encoder to Channel 0 but i am not sure how to set up the counts , i know it is the channel input gain setting and i have read posts that show the command and position traces on top of each other but i cant seem to achieve this . see attached picture
    Also i cannot untick the output boxes on the digital I/O screen for bit 2 and 3 ( i have probably set it as an output somewhere by mistake )
    Regards
    Sean
    Junior Member
    May 2006
    3833
    Re: KFLOP Stepper Motor Encoder Set up
    Hi Sean,
    It looks like the plots would overlay if you zeroed both the command and encoder position before the move so they both started at zero.
    I think you have
    KStepPresent=TRUE; // enable KSTEP input multiplexing
    still set in your INIT Program which tells KFLOP to use bits 2 and 3 to control the multiplexing of the 16 KStep Opto inputs. Remove that and re-boot KFLOP.
    HTH
    TK
    http://dynomotion.com
    Jul 2018
    47
    Hi Tom
    Thank you for your speedy reply , zeroed the plots and overlayed perfectly
    i have commented out the ,
    saved the file and rebooted
    But channel 2 and 3 are still ticked ,if i click on them the tick disappears for a millisecond then re-enables as an output
    Thank you so much for your help
    Sean
    Junior Member
    May 2006
    3833
    Hi Sean,
    Maybe you Flashed KStepPresent into KFLOP. Reset KFLOP to its default state by re-Flashing New Version.
    HTH
    TK
    Jul 2018
    47
    Hi Tom
    Thank you ,that was the problem have re-flashed new version and can no set 2 and 3 as inputs
    I have attached encoder output trace from channel 0 (x axis) if you wouldn't mind having a look to see if i'm on the right track as i'm not 100% sure what i am looking at :-)
    Sean
    Jul 2021
    3
    Join the Illuminati official of wealth and powers fame and protection and get rich from generations to generations. interested contact us on WhatsApp +14305583146
    Jul 2021
    3
    Join the illuminati brotherhood secret society
    Jul 2021
    3
    Join the illuminati brotherhood secret society USA
    Jul 2018
    47
    Hi Tom
    this topic seems to have been hijacked with spam
    I have added error v output plot
    sean
    Quote Originally Posted by sean69_uk View Post
    Hi Tom
    Sean
    Junior Member
    May 2006
    3833
    Hi Sean,
    See how the error oscillates about 25 steps peak-peak? I don't think it is caused by the closed loop feedback. You might do an open loop move to verify that (set PID gains to zero). We don't know anything about your machine or how it is constructed or what the resolution is. Looks like there are about 16 oscillations. If you have a lead screw does it rotate about 16 times for that size of move?
    Note Alt-PrintScreen will capture a single window.
    Its good to attach the raw data so we can re-plot it and zoom in to see things. You may need to zip it to reduce the size so cnczone will allow it.
    TK
    Jul 2018
    47
    Hi Tom
    Sorry for Delay i'm still on central time
    My machine is a retro fit to a Boxford VMC
    Stepper motors are STC HY200-2232-190 200 Step hybrid running on 48v Supply
    16 T pulley on motor to a 20T pulley on a 2.5mm pitch Ball Screw
    200 ppr optical encoder mounted to motor shaft with channel A connected to A0+ and channel B to B0+ on kanalog
    Table moves approximately 35mm during the test 14 turns of ball screw , hard to measure accurately as its all enclosed
    hope this helps
    SEAN
    Junior Member
    May 2006
    3833
    Hi Sean,
    No rush from our end
    If I did the math right that comes out to 3200 steps/motor rev and 1600 steps/mm (40640 steps/inch)
    So the move of 50000 would be 50000/3200 = 15.625 motor revs which matches the number of oscillations. Strange to have 25 micro steps of error when measured at the motor shaft. If we were measuring at the lead screw or with linear scales at the stage then an off center pulley or lead screw wobble could be the cause. But this is measured right at the motor shaft. A poorly mounted encoder disk (off center) can cause something like this.
    This corresponds to +/-12 steps / 1600 step/mm = +/- 7.5um
    You might try moving very slowly or to specific motor rev angles and stopping to see if the error is purely a function of motor angle as opposed to time.
    I'm surprised this works. Connecting to one differential signal only and leaving the other floating is normally unreliable. But loosing counts and such would show up differently than an oscillation like this.
    TK
    Jul 2018
    47
    Hi Tom
    Thanks for the quick reply , i will re check the encoder wheel as its one of the Broadcom ones where the wheel is tiny and not part of the assembly you have to use a setting tool to align the sensor housing .
    i did try connecting the A-B channels to A0+ and A0- firstly on the kanqlog but didn't get an output signal .it is a single-ended quadrature encoder as only has A and B channels
    Sean
    Junior Member
    May 2006
    3833
    You should add a differential driver such as this or connect to KFLOP's single ended inputs.
    TK
    Jul 2018
    47
    KFLOP's Single ended inputs on JP7 that is connected to the kanalong JP14 , break into the ribbon cable ?
    "JP1 converts 8 of the signals and connects them to Kflop I/O bits 0-7 (Kflop JP7 Pins 7-14) which are Kflop's 4 encoder A/B input channels"
    Junior Member
    May 2006
    3833
    The encoder inputs can be moved from JP7 and JP5 to JP4 and JP6. See the MuxEncoders.c example.
    TK
  17. #17
    Jul 2018
    47
    Tom
    Couldn't see any wobble in encoder wheel so replaced the whole encoder , larger wheel diameter with 500ppr
    attached are screen shots and file , all settings the same except input gain changed to 1.6 from 4 so command and position traces align
    Attached Thumbnails Attached Thumbnails open loop error new encoder.png   open loop position command new encoder.png
    Attached Files Attached Files
  18. #18
    Junior Member
    May 2006
    3833
    Hi Sean,
    That looks good to me. I think its time to go closed loop to see if you can reduce the errors. Low Pass filter, I gain, and Feed Forward.
    TK
  19. #19
    Jul 2018
    47
    Thanks tom
    glad thats ok , because enabling the MUX for encoder inputs on JP4 and JP6 messed everything up and all the bits stayed high regardless
    Am i adjusting I gain to get output trace to match the command and position traces as attached picture
  20. #20
    Junior Member
    May 2006
    3833
    Hi Sean,
    That doesn't make sense. Maybe you were missing a GND or miss wired?
    No. The goal is make the error plot as close to zero as possible. Right now the position is lagging behind by about -30 counts while moving positive and +30 counts while moving negative. The output should be going to 30 steps to correct this. The Integrator works by looking at the error and based on the magnitude of the error and the magnitude of the I gain and ramps correction (output) based on their product. In your case the Integrator is correcting the error but ramping so slowly it has only corrected 2 steps of the needed 30 by the time the move is over. Then on the move back the error is +30 so the Integrator ramps negative but only gets back to zero by the time that move is over. The idea is to make the Output correct the error as quickly as possible without over-correcting and going unstable.
    TK
  1. Encoder for stepper motor
    By ssjantonio in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-16-2016, 03:25 AM
  2. Kflop + stepper motor axis drifts
    By konstantinshr in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-13-2016, 05:32 PM
  3. best Big stepper motor work with Kflop+Kstep?
    By mismis in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-19-2012, 04:16 PM
  4. encoder for stepper motor
    By 15mgtar in forum Stepper Motors / Drives
    Last Post: 09-22-2009, 04:47 PM
  5. encoder-stepper motor
    By granado in forum Stepper Motors / Drives
    Last Post: 11-29-2004, 11:38 AM
