591,534 active members*
5,098 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Kia KT21 AL-25 Chuck closed not detected
    Oct 2013
    29
    I have a Kia KT21, 1994, with a Yasnac LX3 control.
    When I press "SELECT" + "FOR" or use the command M3 to turn on the spindle in work grip "EXT" mode, I get the alarm message "AL-25 Chuck closed not detected".
    Parameter #1000 in the diagnosis screen is 00100000 (hex 20). No matter the chuck is closed or opened.
    When I switch to work grip "INT" the machine works like expected. The work grip key switch seems to work. The selected mode is represented correctly in parameter #1037. The LEDs of the sensor on the draw tube show the status of the chuck correctly.
    Has someone an idea what I could do to fix that issue?
    Apr 2009
    1263
    Typically when you switch from External to Internal chucking, the prox switches on your actuator are switched as well. This usually requires adjusting them since the actuator piston and attached dog are no longer stopping in the same position. I believe a simple adjustment of the prox switches will cure the issue.
    Best regards,
    Experience is what you get just after you needed it.
    Oct 2013
    29
    Re: Kia KT21 AL-25 Chuck closed not detected
    Thanks for your help!
    The sensor was slightly misaligned and additionally the connector was not connected properly
  1. KIA SKT 21 Won't Move with Chuck open
    By quirino18 in forum Hyundai Kia
    Last Post: 01-03-2023, 12:04 PM
  2. chuck open closed 840d
    By jamienw in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 06-09-2015, 07:42 PM
  3. M3/M4 not possible, chuck isn’t closed
    By TOlm in forum SIEMENS -> ShopTurn
    Last Post: 03-09-2010, 06:20 PM
  4. Alarm-25 Chuck not closed?
    By panaceabea in forum Hyundai Kia
    Last Post: 02-17-2010, 03:13 AM
