504,350 active members
3,748 visitors online
IndustryArena Forum > CAD Software > Rhino 3D > Kink to Knot conversion
Results 1 to 5 of 5
    Mar 2010
    89
    Can someone suggest me commant to convert sharp corner control point to smooth?
    Feb 2007
    11
    Re: Kink to Knot conversion
    Can you not just fillet the curve?
    Ted
    http://www.RhinoCanada.com or http://www.ted-kyte.com
    Mar 2010
    89
    No - i need point editing.
    Feb 2006
    173
    I would probably rebuild the curve.
    Mar 2010
    89
    Not good idea, LN-JET.
    First bad thing is i cannot rebuild selected curve points - command not applicable to selection, only to whole object.
    Second bad thing - result will be single segment curve. I cannot explode it further.
  1. Moving Knot vs. Shaft
    By InPhase277 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-23-2012, 12:34 AM
  2. celtic knot wedding/garden arch
    By Mountaincraft in forum General Woodworking
    Last Post: 07-01-2011, 01:25 PM
  3. How can I simplify variable knot..
    By gogego in forum Okuma
    Last Post: 02-11-2011, 04:27 PM
  4. Moving Knot
    By MunchyMonster in forum DIY CNC Router Table Machines
    Last Post: 11-05-2010, 11:52 PM
